Results 1 to 17 of 17
Thread: NEW fill, just installed, results?
    So, only have the 6 way from Walmart right now, ordered the T100..
    TC - 0
    FC - 0
    PH - 7.2ish?
    T Alkalinity - 40
    Stabilizer - 10ish?
    Total Hardiness - 100
    What to do? I know I need bleach, but man these colors are hard to decipher. Maybe I can post pic
    SW, Virginia
    16,400 Gallons AGP
    27'x52" Esther Williams
    Hayward Sand Filter
    Dynamo pump
    Solar Cover
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Re: NEW fill, just installed, results?
    I'm sure there will be some experts chime in here soon, but first and foermost get some chlorine in your pool =). You will need chlorine and some stabilzer. You can use unscented liquid bleach form wal-mart or such and wal-mart or any pool store will have stabalizer. Then take a few minutes and read, then re-read pool school. A wealth of info in there. Congrats on your new pool!
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    Thanks so much!!! Have read pool school prob 5 times...prob need to keep doing it over and over, haha! And, thanks!!!
    SW, Virginia
    16,400 Gallons AGP
    Hayward Sand Filter
    Dynamo pump
    Solar Cover
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    I have been using this method for 2 years, since converting my baquacil pool over to chlorine and I have to say I LOVE it. One I get my numbers in check at the beginning of the season my pool is virtually Trouble Free. Adding a few quarts of bleach a night and testing all my other numbers weekly is about all I have to do. Let me warn you though, if you are like me and love the sight of the clear sparkily water, then the little dirt that shows up on the bottom every day will drive you nuts...lol..lot's of vacuuming goes on here.
    Haha, love it! Vacuuming alot, no prob and I am ready to keep bleach in stock
    SW, Virginia
    16,400 Gallons AGP
    Hayward Sand Filter
    Dynamo pump
    Solar Cover
    Butterfly's Avatar
    South Carolina
    10,045
    First, you should raise your TA to about 70 using baking soda.
    Then, retest pH and adjust if needed. pH should be 7.4ish.
    Add enough bleach to maintain about 2ppm FC.
    Your fresh water fill CYA will be zero. It will only be in your water if you added it.
    Add enough CYA (via sock method) to reach about 30 for now.
    24 hours after your CYA has dissolved from the sock, assume it is there and adjust your FC level accordingly.
    Do you know how to use the PoolCalculator.Com?
    You're done SLAMing when:
    Thanks! I think I have figured out the pool calculator and my TF test kit got here today, I will post results asap. Thanks again!
    SW, Virginia
    16,400 Gallons AGP
    Hayward Sand Filter
    Dynamo pump
    Solar Cover
    Good for you. Yes, the order of importance is pH first (since that can damage equipment if too low, and too high is bad as well), TA next if it is low enough to affect pH in a big way (which yours is), the chlorine and stabilizer (CYA) at the same time. After that is under control, then fine tune the CH and TA as needed.
    [EDIT] I have that wrong -- fix that super low TA first .... Thanks Butterfly
    [quote:Jason Lion]There are a lot of special cases. A simplified list is something like:
    If TA is below 50, raise TA to 50
    If PH is way out of range, adjust PH
    If CYA is way too high, lower CYA
    PH
    CYA
    Raise TA if needed
    CH, adjust CH on it's own day
    Lower TA if needed
    ---[/quote]
    K, this am did the TF tests:
    FC .5
    CC .5
    TC 1.0
    PH 8.2
    TA 130
    CH 70
    CYA Have done twice and each time water all the way to top and still see black dot perfectly
    Any suggestions, thanks!
    SW, Virginia
    16,400 Gallons AGP
    Hayward Sand Filter
    Dynamo pump
    Solar Cover
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    Did you add CYA to your pool?
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    Tap water will not have CYA, so you must put it in. Don't bother to retest for a week or even three, just proceed with your calculated value.
    You can add CYA separately, or in combination with the needed chlorine in the form of dichlor. Pool Calculator can do the math either way. See The Effects of Adding Chemicals at the bottom.
    No, I haven't added cya silly me, sorry. I'm trying the bbb method, so didn't know what to do from here tonight. I used calculator but it says to add muriatic acid, I don't have that? What is the sub using bbb?
    I'm so lost and ignorant with these chemicals? Thanks!!
    SW, Virginia
    16,400 Gallons AGP
    Hayward Sand Filter
    Dynamo pump
    Solar Cover
    You can use muriatic acid or dry acid (pH Minus) but muriatic is cheaper. Find at pool store, hardware store, or paint store.
    Also know that CYA has an acid effect so use Pool Calculator to determine that, use less muriatic acid.
    Read Pool School on chemicals. Print what is hard to understand, eventually you will get it.
    Will do, thank you so much for all the info, have a great 4th!
    SW, Virginia
    16,400 Gallons AGP
    Hayward Sand Filter
    Dynamo pump
    Solar Cover
    Butterfly's Avatar
    South Carolina
    10,045
    We suggest the sock method for adding CYA and only add enough to get to about 30.
    24 hours after the CYA dissolves, assume it is in your water and adjust your FC levels accordingly. Use the CYA/Chlorine chart in Pool School.
    For now, with zero CYA, you should maintain about 2ppm FC.
    Use the Pool Calculator for doses. Post back with any questions.
    You will get comfy with all of this chemical stuff soon
