Thread: New Pool First Test Results Help!
    Mar 2011
    NY
    17
    Hi all, been lurking for the past few months as our pool was built. Pool is a 16x36 Vinyl Liner, 3ft shallow end, 8ft deep end. Also have Pool Pilot Digital. Pool has been running for about 2 weeks with only the salt the pool builder put in. They came today to go over everything and told me to slowly add 3lb of stabilizer into the skimmer tonight and 3lbs into the skimmer tomorrow night, and not to swim in it for 3 days. Pool has been crystal clear since day 1.
    Here are my test results using my TF-100
    FC-1
    CC-.5
    TC-1.5
    PH -8.2
    T/A-100
    CH-150
    CYA-0
    Temp-85
    Salt-3,000 PPM
    Not really sure where to go from here. Should I follow the PB advice on the stabilizer?
    Thanks for all your help!
    Scott
    16'X36' In-Ground Vinyl Pool
    Autopilot DIG-220
    Aquacal Heat Pump
    Polaris 9300
    22,553
    Re: New Pool First Test Results Help!
    The first thing you need ot do is get the pH down to about 7.5. Then get the CYA in there. You should also add 2 ppm of chlorine in there tonight.
    Don't worry about testing the CYA for a week. And by the way, if you don't have a good test kit you need to get one.
