Thread: Intellichlor shocking and timer interrelation question...
    Oct 2010
    Eastern TN
    172
    My FC is 2.5 and with my oversized SWG and small pool, 4 hours of super chlorination will raise level. I'm wondering what happens if my Intellitouch is set to run pump for two more hours tonight and I have the super chlorination set for 4 hours. Will it run 100% for two hours tonight and then 2 hours in a.m. or does it count 4 continuous hours and then reset to off only giving me 2 hours of super chlorination?
    Plaster pool inground 22,000 gallons with spa. Pentair Intelliflo, IC40 salt generator, WiFi control/Easy Touch.
    Hayward 1.5 HP pump on 750 gallon spa. Sand filters. Auto chlorinator on spa. Auto water level. Dolphin M500. TF100 XL with Speed Stir. Apera Instruments AI311 PH60 Premium Waterproof pH Pocket Tester
    Re: Intellichlor shocking and timer interrelation question..
    The standard behavior of an IntelliTouch is to force the pump on for the duration of the super chlorinate cycle.
