Thread: Jandy Never Lube valves
    OK, I was working on the plumbing when I realized that the Jandy two and three way valves have an "IN" marked on them. Some of the valves I did correctly and some I got reversed. The three way valves on the return header (manifold) are the right way but the ones on the suction side have the "IN" towards the pump which is sucking in water(was the only way to do them). I also have the two way valves about half the correct way and half the wrong way.
    How critical is this? I can't see what the difference is.
    Thanks in advance,
    14X28 I/G steel wall hump back Kidney 3'-5', 30mil vinyl liner,92" spill over spa, 1hp Hayward Super 11-pool circ., 1 hp Hayward super 11- spa booster, Hayward Tristar waterfall pump through Jandy CS100 for three 24" Brilliant Wonders sheer descent waterfalls and two Jandy Laminar deck jets , Hayward Swim Clear Cartridge 425sqft, Hayward H-series 250,000 BTU N/G, Pro-logic PS8, T-Cell, Hayward Aqua Vac Robotic
    Jun 2010
    Glendale, CA
    513
    Re: Jandy Never Lube valves
    You're fine. You'll note that there would be no way to get the valve "correct" on the 3 ways on the suction side.
    The 2 ways - I guess there is a theoretical pressure where having them backwards creates stress on the gate - I doubt your pool pump is gonna get there.
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    Quote Originally Posted by lightingguy
    I went back and looked at the two way valves and I see what you mean about swinging the gate against the flow. I guess if it ever breaks I will have to replace it but I agree, I don't think it will.
    Mar 2007
    Coastalish 'down easter'
    4,160
    You can also unscrew the 8 screws hat hold the top on and reorient the valve handle (turn the whole top 90 or 180* so things match up to your situation)
    Luv& Luk
    -Ted
    Quote Originally Posted by waste
    Now that's thinkin' outta the box.
