Results 1 to 7 of 7
Thread: Found corrosion at pool base...What to do.....
    I found a 4 inch crack at the base of my pool. Pool store won't give me any help because of liability issues they say. I have read numerous websites about inserting aluminum flashing into the track and to use epoxy to secure it. Has anyone ever tried this? Does it matter if I use the aluminim flashing on the outside wall?
    Also, I have been told that my liner will shrink if I attempt to empty it and do some work. It may hold the summer but I will be worried the whole time.
    Oak Lawn IL
    15 x 30 AG
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Re: Found corrosion at pool base...What to do.....
    Ouch, is that the liner I can see? I'd drain it to fix it and sandwich the crack in aluminum sheet metal. Then get some rubber tape to go over the inside seams. Looks pretty scary, anyway to shore it up with plywood until fall?
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    X-PertPool's Avatar
    Exeter, PA
    1,385
    I really hate trying to fix stuff like this in fear of the pool opening up like a zipper and hurting someone. I use aluminum flashing that is pop riveted from the inside of the pool and then use foam over the metal or tape the edges. If you do try to fix it try not to let the liner shrink (work fast) and make the repair over sized as you are only seeing a small part of the corrosion
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    That's gonna have to fixed from the INSIDE for sure.
    Quote Originally Posted by X-PertPool
    Thanks for the advice. I guess I'm going to have to try it. I can't find anyone in the area to do it for me. I'm not very handy but it's either try or take the thing down. If I'm thinking the right way I can just pull back the liner back enough just to get at it and then hook everything back up. I'm probably going to end up with a pretty wrinkled liner at that spot.
    Oak Lawn IL
    15 x 30 AG
    [quote="MikeInNH"]Ouch, is that the liner I can see? I'd drain it to fix it and sandwich the crack in aluminum sheet metal. Then get some rubber tape to go over the inside seams. Looks pretty scary, anyway to shore it up with plywood until fall?[/quot
    Sandwiching the crack might actually be a great idea. Thanks for your opnion.
    Oak Lawn IL
    15 x 30 AG
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Technically if you get a piece of flashing and tape the edges you should be able to slide it down behind the vinyl with the pool mostly drained. The water pressure should hold it in place.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
