Results 1 to 9 of 9
Thread: How long till chlorine drops?
    O.K. I had to shock for the first time. I had a very light algae or something.
    Once I'm done, how long till the chlorine drops to swimmable levels? I shocked to 24 TC, vinyl 24,000 gallon pool. Temp now about 85, outside temps 100. Lots of direct sun.
    Any guesstimates? And what is a safe tc for swimming, 7 I think?
    18' x 36' saltwater inground vinyl pool
    Re: How long till chlorine drops?
    After shocking a friends pool, we saw FC drop 50% in one day at CYA 30. Drop would be far less at higher CYA levels.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Really though... isn't it ok to swim at shock levels if it's shocked appropriately for CYA? I do remember reading this last summer here on the forums. It isn't gonna kill you and might even assist anyone with athlete's foot who goes swimming :~}
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    We got in that pool at something a bit below shock level and while the day before it fell by 50% in 11hours, when we swam, it fell 25% in 4 hours, so a bit faster than it did with just sunlight.
    Butterfly's Avatar
    South Carolina
    10,045
    Most of us say it is okay to swim with FC above min and below shock level for your CYA level.
    You're done SLAMing when:
    ouachita, it is impossible to guess how long without knowing your CYA level.
    Sorry Jason, CYA is 30. I went by the pool calculator and shocked according to Mustard Algae levels just in case. I know the CYA is low. I'm gonna work on that as soon as the shock is over. By the way, standard shock was listed at about 15. Don't quote me on that. I just went ahead and went to the Mustard Algae level, which I don't think I had.
    You know, July 4th weekend coming up. Gotta use the pool.
    And by the way, I meant FC and not TC on my shock levels. When I started the shock I had.5 FC and .5 to 1 CC. It was hard to tell. Need to order a new test kit! The cylinder is getting old.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Turn your SWG off first, shouldn't take too long 3-4 days maybe. I wouldn't see a reason why you couldn't swim on the 4th. Took almost 10 days for me but my CYA was higher than yours.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    With CYA at 30, the FC level will be done to the high side of normal by tomorrow evening, if not before.
