Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: YAY! Water going in our Used Pool DIY. But, floor wrinkles??
    This project is getting very looooonnnnnggggg. We now have started filling after weeks and weeks... and weeks of leveling Now have installed our liner, unibead hooked onto our receivers (since we have an Esther Williams pool and their bead is a PIA). However, there are very tiny wrinkles in the bottom. As its filling they seem to be coming out. Its almost at cove where the seam is about an inch below. Will these prob come on out? I will try to get pics of the actual wrinkles, they are hard to see unless you are right on them. Any experience with these small floor wrinkles???
    Thanks!!!
    SW, Virginia
    16,400 Gallons AGP
    27'x52" Esther Williams
    Hayward Sand Filter
    Dynamo pump
    Solar Cover
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: YAY! Water going in our Used Pool DIY. But, floor wrinkl
    I would stop filling and get in the pool to see what kind of smoothing you can do. Water is freakishly heavy... wrinkles on the bottom will stay once water is atop them and you can do nothing about it then. It may even be impossible already.
    I don't know much about regular AGP's cuz I slum with Intex but from reading here aren't you supposed to use a vacuum to pull the liner tight while filling? Others will chime in I'm sure. The non slummers :~}
    Good luck, hope it works.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    I loved my Intex pools, lol, I am very much missing it now. Thanks for your reply. I did use the shop vac, but it didn't pull the floor as tight as the walls??? My instruction book didn't mention any vac at all, but, like you said and from reading on here, I think the guy who thouht it up should patent it They are going away alot as the water gets higher, thats why I couldn't decide to stop water or keep going to get them out Me and DH are about to choke each other over this pool. I'm going to take pics now. Can't get the others to post from the build???
    SW, Virginia
    16,400 Gallons AGP
    Hayward Sand Filter
    Dynamo pump
    Solar Cover
    K, here r some pics!
    I will post some more pics of the build. We bought it used and have learned sooooooo much! I need to add up my cost for others trying to decide between used and new
    SW, Virginia
    16,400 Gallons AGP
    Hayward Sand Filter
    Dynamo pump
    Solar Cover
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Well... wrinkles are good for catching debris... shrug. But I'd want to smooth them personally anyway. I know my H would grumble for a lifetime about those. We have wrinkles after two years, but not at first fill. The water does look too deep to be able to do much about unfortunately, it's hard to smooth wrinkles even with only a couple inches of water IME.
    How much stress would it cause to drain some and smooth?
    I couldn't live with those. I'd have to drain/reline/refill. One trick I saw our installers use was to start the filling with most of the liner pulled up on the sides. They used the weight of the water filling it up to smooth out the wrinkles and released more liner as it was needed. We have a perfectly smooth bottom now.
    Doughboy 18x38 AGP buried 2' deep. 18,400 gal. Hayward Power Flo Matrix. Hayward Pro Series High Rate Sand Filter. TF-100 test kit.
    That last pic i the worst one and right along the edge? I am still letting it fill at this point, bc lots of them have came out. I have been in there on my hands and knees working them to the edge. I think I have decided to live with them if they decide to stay.
    However, here are some more pics.
    My totals so far:
    Used pool 300.00
    Sand +/- 1,000.00 (don't even ask...really)
    some new channels 100.00
    new skimmer flange 20.00
    new liner 280.00
    new misc bolts, duct tape, etc 50.00
    So, 1750.00 for a 27' x 52" isn't bad...but my sanity is wavering
    SW, Virginia
    16,400 Gallons AGP
    Hayward Sand Filter
    Dynamo pump
    Solar Cover
    K, so H on way home, we gonna start draining. Thanks everyone. ROTJob, I think that was prob on an overlap? We have no liner to release. It hangs on the bead receiver. I've been in there moving them around with my feet and hands, but still very small ridges. I hope to goodness if we start with no wrinkles, we don't end up wih them in year two , who knows?? Is there anyone out there with experience installing a beaded liner DIY???
    SW, Virginia
    16,400 Gallons AGP
    Hayward Sand Filter
    Dynamo pump
    Solar Cover
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    You're going to drain it to get the wrinkles out? That's a big pool to try and get all the wrinkles out of. We have some wrinkles in our JW oval pool, no biggie. Can't see them when floating around on my back. BTW, I like the bead liners better than the other styles.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    You know what...we said screw it!!! I worked out the noticeable ones ad from what I have found and seen online and with other pools. You're right!!! It's a BIG POOL! Can't get everything perfect. I will never see them while floting around
    It's almost 1/2 full! Kids have already been in it Good times!!!
    Now, I will post my test results prob tomorrow. I tested the water we were filling with before. It had no chlorine - 0 and PH was like 6.8, low. I only had the old 2 way strips from intex pool. Mother brought me 6 way, haven't done it yet. But gonna buy the good test kit
    Thanks so much for the last post, I was really thinking...what! we are gonna drain it and the wrinkles are not even real wrinkles now???
    They will never bother me...
    SW, Virginia
    16,400 Gallons AGP
    Hayward Sand Filter
    Dynamo pump
    Solar Cover
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Good for you!
    Wrinkles make the dirt easier to locate btw... :~}
    ahahahaha, thanks! Kids are already swimming, my stress would have been nothing compared to theirs . But, most of them came out anyway...the wrinkles that is. And, from what I hear will poss have them next year or so on, then, not worth it! Now, to figure out water, lol. I just posted in the another topic, but here is what I have:
    So, only have the 6 way from Walmart right now, ordered the T100..
    TC - 0
    FC - 0
    PH - 7.2ish?
    T Alkalinity - 40
    Stabilizer - 10ish?
    Total Hardiness - 100
    What to do? I know I need bleach, but man these colors are hard to decipher. Maybe I can post pic
    SW, Virginia
    16,400 Gallons AGP
    Hayward Sand Filter
    Dynamo pump
    Solar Cover
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Quote Originally Posted by snyder5
    TC - 0
    FC - 0
    PH - 7.2ish?
    T Alkalinity - 40
    Stabilizer - 10ish?
    Oh, so been there with kids asking to swim. Makes you do things like not drain and refill pools the H insisted had to be done so then you can argue about it for eons... Even while pool is sparkly clear and perfect
    ahhh.. back to you. Yes, bleach.
    If you never added CYA, call it 0. Those strips are junk for CYA. It'll look like 0 till you're over 50ppm and then it's too late.
    You may want to raise alkalinity a tad w/baking soda, but not too much because you can't test w/o strips. Do 10ppm at a time perhaps. Or go halfway and raise it 20ppm but no further. I'd leave ph alone for now. It might raise all on it's own.
    Use 0 CYA for now for the calculator, it'll tell you how much bleach to add. Tomorrow, get stabilizer/conditioner/CYA at pool store or walmart. Decide what level you want to run the pool at, use calculator, get an old sock and a rubber band... hang it and squish it all day. Then change CYA levels on the calculator to reflect how much you put in the sock. Dose pool to the target level for that CYA. Test after dark, dose back to target. Sleep, test again to be sure it's still where you left it (or close) and then either dose or swim.
    Pure bliss will overcome you.
    Thank you so much! You are a blessing
    SW, Virginia
    16,400 Gallons AGP
    Hayward Sand Filter
    Dynamo pump
    Solar Cover
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    It's all new water, I wouldn't sweat the numbers much until it's full. If anything, chlorine is the one you want to keep up but during a fill it shouldn't be a big deal. You really do need to get the good test kit though, strips are close to useless. Have fun!
    Mike
    Jul 2010
    Mickleton, NJ
    229
    Quote Originally Posted by MikeInNH
    ITA
    A good test kit will help immensly b/c you will know what is going on with your pool and between the pool calculator and the good people here you can figure out how to get your levels right.
    Currently Pooless
    Former Pool:Buster Crabbe resin and steel 30'x15' oval 52" ABG pool Pentair sand dollar filter 1.5 Pentair Dynamo pump13,500 gallons
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    Glad you decided to live with your wrinkles... but be aware, the next thing you notice may be little dents. I am almost sure the bottom of mine was perfect, but after we started swimming for a while, the floor surface got lots of little dents in it. These BTW are also perfect for catching the dirt. I don't know why it happened, as I thought the weight of the water was greater at compacting the sand underneath than anything our feet could do... but I have just learned to live with them as well. It's all good. Hardly noticeable by day, but when the light is on at night, it looks like the surface of the moon! I don't turn that light on much!
    Happy swimming!!!
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    22,548
    It's time to get that test kit.
    You need to add 3 quarts of bleach.
    You need to add 5 lbs of CYA if you're using bleach to chlorinate your pool. If you're using tablets don't add any CYA.
    You need to add 7 lbs of baking soda to bring the TA up to 70. If you're using tabs you'll want it higher.
    Looking good so far.
    Thanks all and thanks Bama! We FINALLY got our Pentair Sand Dollar SD40 hooked up today, thank goodness the water still looks as is we just filled it. Also, got my TF TEST KIT today, yay! So, we are trying to figure out the six positions, however, the decal is gone , does anyone have a pic? And, we are clueless, we should leave it on recirculate, right? We think we found this and followed all directions, but have no pressure on the gauge? The water is pumping back in great though. What do we do?? Thanks
    SW, Virginia
    16,400 Gallons AGP
    Hayward Sand Filter
    Dynamo pump
    Solar Cover
  20. Back To Top    #20
    Butterfly's Avatar
    South Carolina
    10,045
    okay, it could just be me, but you are talkin' a little broken or at least sounds that way to me
    Anyhoo,
    1. google your filter for the owner's manual
    2. Filter position should be on filter (not circulate), but circ is okay for right now, but get to 'filter' soon
    3. If gauge is reading zero with pump running, it is broken. Replace it. They are cheap.
    4. Post test results with your new TF100
    You're done SLAMing when:
