Thread: Aqualink RS Heater Question
    Hi guys,
    I have the Aqualink RS pad mounted on my wall in the house. The instruction book says that under the heating section there's a "maintain" setting but when I actually navigate to the menu it isn't there!
    Has this feature been removed from the menu in some of the models? As far as I can tell the heater will not fire unless the Heater button is pressed and the light is green. Then when the heater fires the light turns red.
    Thanks for the input, don't want to heat a pool/spa that I don't know I'm heating!
    -Tom
    17,000 gal plaster with spa. Pentair Clean & Clear cartridge filters. Jandy systems with Aqualink RS and Polaris 360.
    Pool Store free since May 2011!
    Re: Aqualink RS Heater Question
    The heater needs to be configured and enabled, a target temperature setting needs to be set and enabled, and then maintain will appear.
