Results 1 to 15 of 15
Thread: Hello - just received my intex last night
    Im glad i found this site. What great info I have found so far. I just received my 12x24x52 intex last night and Im excited about getting it up. I will be posting some pics later on. Thanks everyone.
    Pool: 10k gal, sand, AG
    Taylor K-2006 Test Kit
    Jeremy
    Re: Hello
    Welcome to TFP!
    Feb 2008
    Denton, TX
    5,061
    Re: Hello
    Welcome to TFP! You will enjoy your Intex.
    jsf0656's Avatar
    Apr 2010
    south georgia
    313
    Re: Hello
    WELCOME!
    18x52'' intex AGP, 6981 gal, 2650 intex sand filter,
    thru wall skimmer, SWG, 52'' 20G overlap liner, intex pool light
    Re: Hello
    I need a little help. Ive got the pool up and running. I just started the pump tonight and it keeps beeping and reading "90". So i backwashed and rinsed and its still reading 90 and beeping. Any advice??
    Jeremy
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Re: Hello
    Did you get the combo pump/filter/saltwater chlorine generator?
    Love TFP? Become a
    TFP Supporter!
    22,553
    Re: Hello
    Error 90 is a flow problem error. Make sure you have all the air out of the pump and the plunger valves open and that the flow switch is in the proper direction.
    Re: Hello
    I do have the pump swg combo. Last night I read that the flow sensor might have something to do with it. So i took it apart and put it back together and it worked just fine the rest of the night. Thanks so much for your help and suggestions.
    Jeremy
    Re: Hello
    Im back with the same question again. My swg kept reading 90 no matter what I did. I finally unscrewed the skimmer where it connects to the outlet and there was a big gob of debris stuck there. I turned the pump back on and the water flow is amazing. However, after about 2 minutes it starts beeping again. Im so discouraged on what could be wrong. Ive taken the flow sensor off and cleaned it and put that back together as well. Nothing.
    Jeremy
    22,553
    Re: Hello - just received my intex last night
    If you found a pluggage once you might want to check the rest of the hoses.
    Ive done it all. Cant figure it out. Unless its a faulty flow sensor? Thanks for you help.
    Jeremy
    One thing, when you say make sure you have the flow sensor in the right direction, the right direction is that when you have proper flow, the little white tab thing should be up, not hanging down. Right?
    Jeremy
    22,553
    Yes it should not be hanging down when the pump is on.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Air? Is it fully bled?
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by TAMMY8787
    Not sure how the all in one is constructed exactly, but from the pictures I have seen, make sure the flow sensor is installed "perfectly" horizontal. Meaning, the axis of rotation of the magnetic "flap" must should be parallel to the ground. I found on my swg (I have the separate intex one) when I am on low pump speed (I have a 2 speed pump) if mine was not horizontal, it could hang just slightly down in the flow due to friction in the pivot caused by the flap not being able to move directly with flow and up.
    On a side note, I personally would not buy a "built in" swg. Eventually it will fail, and the intex is basically replace the whole thing when the cell is dead (from a cost perspective...at least what I have seen). I am assuming the pump will last longer (most do...not sure of intex though). In addition, having a separate unit lets you move to a new system/pump setup if needed. An example would be a pool size upgrade, where a higher flow rate filter system is desired, but the swg would still work. My two cents for future purchasers of the this system....
