Thread: Help me make the perfect pool, well maybe
    May 2011
    British Virgin Islands
    22
    Hey everyone.
    Posted in the "under construction" and didn't get the kind of response i was hoping for so i'm trying here with a different approach.
    I saw a great thread where someone asked if you start over with your pool what would you do different etc. So kind of the same, is this was yours, what would you do?
    So right now we have no specifics, only a drawing on the plans which states an oval pool 40' x 25' and 8' deep is the retaining wall and the rest of the pool follows natural contours of the land. See my wonderful drawing!
    [attachment=0:2dz31sz2]pool%20plan.jpg[/attachment:2dz31sz2]
    So my question to you, is what would you do? How many skimmers, returns, drains and where. Whats your choices on filters etc - All comments welcome!
    Hopefully with your help we can create a fantastic pool and this thread might also help others.
    Thanks
    Andrew
    Regards
    Andrew
    British Virgin Islands, Caribbean.
    Freeform pools - 12,000 gallons
    DE Filter
    In Ground Pool
    Pump Info to follow
    May 2011
    22
    Re: Help me make the perfect pool, well maybe
    Does anyone know if this would be better in a different forum as i'm not getting any responses?
    Regards
    Andrew
    DE Filter
    In Ground Pool
    Pump Info to follow
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,045
    Put a skimmer at the extreme downwind end. Then one or two others spaced equidistant.
    I'd plumb the main drain with it's own valve.
    Lots of returns. If I could redesign my pool, I'd have returns near the steps so I could aim them at the steps. Too much debris settles on the steps in my pool.
    Generously radius any corners. It's hard to brush otherwise.
    I don't know enough about what equipment is available, but if the filter only has run and backwash, install a multiport valve in the plumbing. I have no waste setting and wish I did.
    Leave lots of room around all the equipment and use lots of unions. open-letter-to-mr-pool-builder-t28680.html
    May 2011
    Orange County, CA
    696
    Ours is free-form (it was built before we bought the house). But, I wish it were rectangular so that we could purchase an automated pool cover for it. We're usually sunny and warm here, but not that warm that we don't need to heat it in the summer. A pool cover would help to prevent that heat loss. In addition, we have lots of trees nearby and an automated pool cover would be very useful then.
    Another thing is the depth. With the rocks there, kids will be very tempted to jump off into the deep end. Make sure that they are situated near the deep end and that it will be deep enough. Ours is 10'.
    Yet another thing... add more than one lighting niche. The trend these days is to use lower output LED lights. Make sure to install 2 or 3 light niches if you want your pool well lit. Extra skimmers is a good idea if you have plenty of debris, and think about installing an extra vacuum side line to the pool for a vacuum-driven auto cleaner.
    And where's the spa?
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    That will appear to be a diving rock and steps below are a hazard.
    Rocks below the water line are impossible to keep clean.
    May 2011
    22
    The rock isn't for diving, purely a feature. The islands here are full of boulders so people encorporate them into everything. However, safety is a good point and didn't think of it like that.
    Regards
    Andrew
    DE Filter
    In Ground Pool
    Pump Info to follow
