Thread: Knocking Sound Coming from Return
    Mar 2011
    Houston, Texas
    413
    I'm hearing a faint knocking sound coming from one of my returns. The same return also has a few bubbles coming out of it. They don't come from the opening of the return, but they come from the small space between the plaster and the return fitting. Could this be from my SWCG? The flow from the return is no different than the other four returns of the pool so nothing appears to be obstructing the flow from that return. I've noticed this for months. Any ideas?
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
    22,553
    Re: Knocking Sound Coming from Return
    That's a good one. I suppose it's possible it's possible for the hydrogen bubbles to build up behind the faceplate and bubble out. What happens if you remove the fitting? Does it still bubble?
    Mar 2011
    Houston, Texas
    413
    I thought it might be hydrogen bubbles as well. I haven't tried removing the fitting yet.
