Thread: How to clean Hot Tub
    Mar 2011
    Houston, TX
    72
    I have some sediment in the bottom of the hot tub and really don't know how to get it out. I don't have a vacuum. All I have is the polaris for the pool and the hose isn't long enough. I guess I could attempt to sweep it into the net but I doubt I will be able to catch it all. Any ideas?
    18,500 gallons, Cartridge Filter, In Ground Plaster. Jandy CL460 Filter
    Jun 2010
    San Antonio
    424
    Re: How to clean Hot Tub
    You could take a length of poly hose and siphon it out.
    Larry in Texas
    Above ground 7,700 gallons, 19 inch sand filter ( 2 sq. ft.), Liquidator, and a WaterWay Hi-Flo Pump with an A.O. Smith 1 hp SF 1.0 motor.
    Apr 2011
    Lynchburg VA
    393
    I attach the vacuum head from my pool onto a 1.25" pool hose, place it in the bottom of the hot tub and siphon debris out.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Mar 2011
    Houston, TX
    72
    I don't think I have a vacuum connection in the pool. I guess siphon is the best alternative.
