Thread: Confused on Intex SWG's and hookup
    Jun 2011
    Northern Maryland (near Delaware)
    170
    Season 2 of my pool, using BBB at this point, or at least BB (no Borax yet).
    Anyway I see many references to Intex SWG's, I am really unsure of What I see on the Intex Site vs BJ's Krystal klear vs Leslies Deluxe A/G.
    Are these adequate for a 15X30 A/G that is open May-Sept?
    I see no references to Cell Replacements.
    Now I don't mind spending a little extra to get something that is more reliable and is servicable.
    Next,
    Electrical, I have a single outlet (twistlock) for my 1 speed pump hooked to a timer that is wired in. Do most SWG's have their own timers and cycle the pump or would I need a second outlet? My county is strict on homeowners doing work around pools and I had an electrician do the hookup because I have an aqualuminator and according to code I had to run shielded cable back to fuse box and the aqualuminator cord had to be less than 5 or 6'. And I was inspected 3 times (neighbors called). But all is in order, but I am trying to minimize costs and understand if I would need a second outlet or if I could bypass the timer mode via switch and keep the outlet hot and use a SWG timer?
    I would consider other brands too or just stick with BBB, my pool dealer has one for like 1200, he believes bigger is better so it works less. And local pool supply is against SWG since they say not many folks use them. I am mixed at this point.
    15'X30'X52" AGP AquaSports Grande Buttress Free (10,620 Gallons), Hayward Dreamline S190 W Zeobrite, 1.5 HP Hayward PowerFlo LX, AquaLuminator Light+ fountain attachment, Pool Rover, Tf-100 test kit, Speed Stir.
    Re: Confused on Intex SWG's and hookup
    The Intex is by far the least expensive. When it wears out you just replace the entire unit. The Intex needs it's own standard outlet and has its own timer which does not control the pump.
    For something better, the next one worth considering is something like the AquaTrol, much more expensive and with several additional features. The AquaTrol has replaceable cells, has a timer which does control the pump, works with your existing twist lock outlet (pump plugs into the AquaTrol), and is all around better.
    Jun 2011
    170
    Thanks, I looked at a user manual and it had a twist lock cord on AquaTrol but a conventional plug in the back. Do you know if the pump output is Twist Lock too and maybe they had the wrong picture? If that is the case this would be ideal.
    22,553
    You can get them either way. With the twistlocks or without. They just add TL to the model number to designate twistlocks.
