Thread: Got to be HAPPY!!!
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Got to be HAPPY!!!
    Got to tell you all, it's been a good forum. Here are my readings from last night:
    FCL 4.25
    tCL 4.25
    pH 7.9 (Always adding muriatic acid and 1 yr anniversary in November)
    ALY 83
    CH 217
    CYA 63
    They're almost perfect.
    Can't be happier with the way the pool looks except for all that visible dirt on the bottom that always needs cleaned...
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Feb 2008
    Denton, TX
    5,061
    Re: Got to be HAPPY!!!
    Aside from you pH being marginally high, I'd say that you are looking good.
    Dec 2010
    560
    I drop 1/4 gallon of muriatic acid in my pool almost daily. It's always on the high side...
    TFT-100 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    So the test results are decent, but how's it look? Do people suddenly get the urge to go swimming when they see your sparkling water?
    Dec 2010
    560
    I've got some of my pictures posted all over this forum Richard, but here is another...
    My entire construction from beginning to yesterday is at
    http://www.golfmd.com/baurphotoalbum/poolconstruction
    Lana's 23 year old daughter wants to have a full-out party blast at the end of the year for all of her friends to show it off, but I said ABSOLUTELY NOT. They're way too much into partying. Would be too stressful, but fun to watch until they get stupid.
    TFT-100 test kit
    CH is a bit low.
