Thread: Need help with intermatic timer hookup.
    Hi All,
    I'm replacing my old Intermatic manual timer with the EH10 digital model, Trouble is it doesn't work
    I hooked up the timer as I thought it should be however it didn't send 120v when I switched it manually. I then saw on page 7 of the manual I need to install a jumper between post 2/3 (line-black wires). I did that and turned it on and it popped my breaker. his is where I stop and ask for help.
    Maybe I'm missing something. Pump is 120V. Here is a link to the manual which seems poorly written to me. I hooked up the old one no problem so I'm not sure why this one doesn't work.
    http://www.intermatic.com/~/media/fi...20english.ashx
    Thanks for any advice. I don't want to burn out my pump due to incorrect wiring.
    Joe
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    Re: Need help with intermatic timer hookup.
    The most common way to wire a 120 volt pump to that timer is to connect both the power supply white wire and the pump white wire to #1, power supply black wire to #2, a jumper from #2 to #3 and the pump black wire to #4.
    Are you sure that the power supply, timer, and the pump are all setup for 120 volts?
    Yes its all 120. Currently I have it hooked up as follows,
    Slot 1-Neutral from house
    Slot 2: Line from house
    Slot 3: Line to pump
    Slot 4: Neutral to pump
    Thats how I thought it said to hook it up. I tried it your way and it works no fire yet either so thats probably the correct way.
    Thanks!
