Thread: Steps to Balance after Refill
    Jun 2011
    San Jose, CA
    5
    I am new to the site. Thank you for the great information and instructions!
    I refilled my pool and followed the first 5 steps in Beginners Guide for Seasonal/Temporary Pools. After 4 days of adding 10 pounds of Dichlor my test results are:
    FC 4.5
    pH 7.2
    CH 100
    TA 70
    CYA 0
    Do I need to wait few more days before I will be able to measure the true CYA in the water?
    What steps do you recommend next? When can I start adding borates?
    20,000 gallon outdoor in-ground plaster pool; 2-speed 1HP Pentair SuperFlo pump; Hayward Perfex EC65A 27 Sq ft DE Filter.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Steps to Balance after Refill
    Welcome to the forum
    It may take a few more days for the CYA to show on testing, but should be about 30.
    You need to increase your CH to 250 - 350 range.
    Do borates after everything else is balanced and confirmed
    You're done SLAMing when:
