Thread: Sparking water to "sorta" cloudy or dingy after heavy rain
    Near Nashville TN
    50
    30,000 gal Vinyl- FC-4 CC-0 TA 80 PH 7.8 CYA 60 82 degrees
    Added some acid to get ph down a little- also added 96 ozs of bleach- it's all I had left.
    Any ideas? Thanks!
    20x40 In ground Grecian Lazy L- Vinyl
    AutoPilot SWG Dig-220, SC-48
    Hayward Dual speed 1.5 hp pump
    Hayward sand filter
    Blue Diamond Robotic Vacuum
    BBB method BABY!!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Sparking water to "sorta" cloudy or dingy after heavy ra
    Patience....
    And you already seem to know that your FC should be higher with 60 CYA.
    Storms often blow in organic debris. It can take a little while for the chlorine and the filter to catch up. Raise the FC level to the top of the recommended range and give the filter some time to catch up.
