Burn off?
Earl42
0
38
Wichita, KS
I left my cover off all day today and burned off 8ppm of FC. Is this normal for a CYA of 70 with 103 degree weather? Also FC dropped from 8 to 0. If I add enough chlorine to get it back to 8, is it safe to swim, or do I have to shock it? CC was maybe .5 (very slightly pink) clear with one drop of R-0871.
Also, pool is not 17K, more like 13K gallons. I will fix my sig when I do some better measurements.
I have a CYA of 95, I'm keeping it around 11 FC, yesterday was full sun all day long and I lost 5 ppm. When covered I average about 1.5 ppm loss per day.
Plus I REALLY need to clean it. I'm assuming my biggest problem is that the past week+ it has been covered most of the time and I don't pay as much attention to leaves and dirt collecting in the center, I'll bet once I clean it my loss will be much less.
Different problem now. I am shocking it. But, every time I add large amounts of chlorine, I get a much higher FC then I should per the pool calculator. I am pretty sure of my 11-12K gallon size. I tried to shock up to 28 and ended up at 40+. I waited 1 hour after putting in the chlorine to test. What else could I be doing wrong?
I think Dave means the pool size calcs.
Are you using 6% bleach?
Also, Are you adding gallons or jugs? i.e. when the PC calls for 5 gallons (3.5 jugs) are you adding 5 jugs?
When I enter 5 jugs instead of 5 gallons in the PC I get that it adds exactly 40 ppm FC.
I am using 96 ounce jugs of 6% bleach. I am pouring in the number of jugs that it calls for. I do have the jug size set to 96 ounces.
to go from 4 to 28 FC in my 11370 Gallon pool, it says to add "4 gallons 2 quarts or 5.9 (96 oz) jugs" so I added 6 jugs at 96 ounces each.
Is it mixing well in the pool? If you have double-checked all your numbers and tests, I would say trust your pool. I think the pool calc is intended to get you in the ballpark, and each situation might need to be tweaked a bit. Although, 6 jugs to 4 jugs is quite a big tweak.
