Thread: Inground Pump For Above Ground Pool
    Quick (and maybe dumb) question... Can I use an inground pool/filter setup for an above ground pool?
    Thanks
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Inground Pump For Above Ground Pool
    Yes, but naturally you don't want to use a 1 HP Superpump and 300lb sand filter on a 12' Above ground pool. It won't really hurt anything but it's a bit overkill. Basically the big difference between an in-ground pump and an above ground is that in-grounds are self priming, where as an above ground pump relies on the the skimmer being higher than the pump to force feed it water to achieve a prime.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
