Thread: Give me reassurance for my husband.
    Jun 2011
    Albuquerque, NM
    77
    So my husband is out of town since the pool was filled. His concern is that I'm burning through the bleach too fast and so I must be doing something wrong.
    At the end of the day I add 1.5 to 2 CUPS of 6% bleach to bring my FC back up to about 5. I'm still going off of test strips here but here are my typical numbers
    Before adding bleach at the end of the day:
    FC 3
    TC 3
    Ph between 7.2 and 7.6
    TA between 80 and 120
    TH between 50 and 100
    After adding my 1.5 to 2 cups of bleach in the evening
    FC 5
    TC 5
    All other numbers pretty much equivalent.
    I don't have a way to test my CYA, but on Saturday after the fill I dissolved enough granular CYA to make the pool 30 ppm. So that is what I am basing my targets on.
    I have been checking in the morning as well and the numbers hold up overnight.
    My husband is convinced I don't have enough cya in there and that I should not have to add bleach each night.
    I do live in a sunny climate and the pool receives about 6 to 8 hours of full sun each day, so maybe I should up the cya. Also how warm should I let the pool get with the solar cover on? Tonight it is reading almost 90, of course that is on the immediate surface. I keep the solar blanket on whenever we are not in the pool and overnight.
    Opinions?
    Thanks!
    Cindy
    4.8 K gallon AGP: sharkline opera 12'x17'x52"
    Sandpro 4511 sand filter and pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Give me reassurance for my husband.
    Sounds about right to me.
    My pool is roughly 3X the size of yours, and I run through 2-3 cups of 12% a day.
    2 ppm of chlorine, which comes out to just over 2 1/2 cups of 6% bleach, a day is typical for a pool that size. If you are under that, you are doing great.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Tell that man to buy you a cool one! Good job.
    Jun 2011
    Albuquerque, NM
    77
    Thanks! I'll be sure to show him this thread when he returns. Maybe I can get that margartitaville frozen drink maker instead???
    Cindy
