Results 1 to 7 of 7
Thread: Intex 2650 sand filter or Hayward vl40t32????
    Greg78's Avatar
    Jun 2011
    N Ft Myers, FL
    13
    Looking to add one of these sand filter systems to our pool. Intex 16'x48" Ultra Frame (5000 gallons).
    Here is the Hayward: http://www.poolproducts.com/SPP/prod...=AMAZON&FNM=92
    Here is the Intex: http://www.amazon.com/2650-Gallon-Sa...9396188&sr=8-3
    Which filter system would you guys recommend or a different one all together?
    I am wanting to be able to run a vacuum as well, any recommendations on a decent one that would work with either of these filter systems?
    Thanks in advance,
    Greg
    Intex Ultra Frame 16' X 48" (5,000 Gallons)
    Intex Sand Filter System (2650 GPH)
    Taylor K-6000
    BBB
    Re: Intex 2650 sand filter or Hayward vl40t32????
    Neither of your links work.
    Assuming I know which models you are talking about, both of those are fine and about the best you will do in that price range. Getting a larger filter than those is better, but more expensive.
    Greg78's Avatar
    Jun 2011
    N Ft Myers, FL
    13
    Taylor K-6000
    BBB
    May 2011
    Clearwater, FL.
    446
    I bought a used WATERWAY 1 hp with a 22" sand filter setup from craigs list locally.
    paid $100 spent another $100 rebuilding/fixing it up with new sand.
    Works very well for my 15X48.
    I did have to add 1 1/2" Hayward fittings to the pool for the hoses.
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    Greg78's Avatar
    Jun 2011
    N Ft Myers, FL
    13
    Just ordered the Intex one from Amazon as it got great reviews.
    Taylor K-6000
    BBB
    Jul 2011
    NJ
    67
    I went with the Intex as well between these 2 because of double warranty length, more functions on the control valve, larger filter, and higher gph.
    Intex 15x36 Easy Set (2,800 g.)
    Intex 16" 2650 gph sand filter/pump combo & SWCG
    Intex 800 gph filter just for the surface skimmer
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    I realize this is sort of an old post, but I was interested in how your Intex sand filter is performing. I recently bought the 2650 system and am quite pleased with it. Wondering if yours has given you any problems. Other than the freakin' Intex non-standard fittings, I think it's good bang for the buck. Time will tell if reliability is an issue.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
