Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Advice SWG beachfront pool
    Apr 2009
    Lima , Peru
    19
    I think it is time to switch over to SWG I built this pool in 2002 it is about 32,000 gallons. all poured concrete one solid piece . all glass mosaic tile 2cm x 2 cm.
    It is right in front of the beach 40 meters from high tide mark on beach, get allot of wind in the afternoon from the SW (blows sand and wet breeze, it is sunny 98% of the year, 3 south from the equator, summer Jan- March it gets in the 90.s(70.s at night) in winter low 80,s (night low 60.s) here is a link to a photo of it http://www.mancoraperu.com/mancora.vich ... G_4214.JPG the wind comes from the the upper left hand corner of the pool straight from the ocean.
    In our summer I have a very high bather load up to 15 in the pool at times but used allot.
    What SWG should I get to keep up with the usage, location, etc. Is there a SWG that can do it?
    I am tired of the Trichlor tabs as when the CYA gets way up there, the black algae starts up. using over a tab a day if not more in the summer, the PH tends to go up.
    the city water is around 130 ppm TA, PH 7.6 calcium hardness 230ppm total hardness 550ppm
    water here is expensive $2.20 USD per M3 1000lts (265 gal)
    thank you in advance
    LAZ
    16286 gal. 16x32 grecian with 2 shallow ends deep in middle, liner, aquagenie, aqualogic p-4 t-15 swg, 8'x20' solar panels, 16mil solar cover, Hayward 1hp superpump, 2" pipes, Hayward Pro 300lb sand filter, built july 07.
    38,521
    Re: Advice SWG beachfront pool
    I can not give too much advice on the SWG ... may actually need 2 for a pool that size with the load (?)
    Or I would love for you to pay me to add bleach every day
    Is bleach / liquid chlorine not an option due to availabilty / expense there?
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Wowthats nice. I would think a swg rated for sixty thousand gallons would do ya. Pentair sells one. What kind of filter setup do you have?
    Also, during storms do you ever get a tidal surge?
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    I agree with Lershac, get a SWG rated for 50,000 or 60,000 gallons and you should be fine.
    Apr 2009
    Lima , Peru
    19
    jblauert
    liquid chlorine is available at 8% $3 usd a gallon by the time we get it probably 7%, Trichlor tablets are $2 usd a Lb, i am going to check with the dealer here for 55 gallon drums but, i would probably need close to a drum a month. that would cost me $150 a month, the tabs cost me $40 us a month plus draining the pool every 3 months or less.
    Aug 2010
    MA
    173
    No advice to offer here, but just wanted to say that this is beyond gorgeous...my God
    Hands down, this is the best pool setting I have seen during my time here on TFP...and that's saying something
    Completed: June 2011
    18' X 38' IG Vinyl, 3' - 8' depth ~ 24K gallons
    2 skimmers, 2 wall suctions, 3 returns, 1.5" piping
    Hayward Equipment: 1HP Tri-star 2-speed, Aqua-Plus SWG,
    Star-Clear Plus 175 sqft cartridge filter, Colorlogic 4.0 LED
    The Pool Cleaner 4X(suction)
    2011 Jacuzzi J-280 Hot tub
    Apr 2009
    Lima , Peru
    19
    Quote Originally Posted by Lershac
    I will look into that model. I have a big filter starite T-300BP-2, with a 2 hp pumpDuraGlass II StaRite PumpP4RA6G 188L, but will be changing that if I get the SWG will go with Iintelflo vs have never yet had the ocean water get to the pool, not much of tidal surge either the pol is about 11 feet above the ocean level, going to look into the pentair 60k
    Apr 2009
    Lima , Peru
    19
    Quote Originally Posted by mx702
    thank you it was really a real quite an experience building the home and pool as we had no power ythen and was one of the first homes on this beach had to use a bulldozer to knock down the dunes and level the area and build my own 300 ft foot road to get down to the beach here are some more pictures different views http://www.mancoraperu.com/mancora.vich ... G_4280.JPG this one you can see the tile and the mosaic turtles on the bottom, bought those in the US http://www.mancoraperu.com/mancora.vich ... G_4270.JPG
    I just finished building this one at my home in Lima, Peru just replanted the yard, this one is small 11000 gallons 3.5 m X 9 m the one above at our beach in Mancora, Peru
    http://www.mancoraperu.com/images-a1/DS ... isidro.JPG
    http://www.mancoraperu.com/images-a1/DS ... Isidro.JPG
    I am going to sleep thanks to all for the tips and advice
    Apr 2009
    Lima , Peru
    19
    thank you, i will get the 60,000
    Jul 2007
    Brisbane, Australia
    874
    if water is expensive you could get one of the models that work with sea water and use sea water in your pool, provided the rest of equipment can handle it
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Quote Originally Posted by Strannik
    I would NOT do this. Salt in the ocean is generally 10 times as concentrated (depending on ocean conditions) at about 35000 ppm. A regular salt water pool at concentrations for use with a SWG is around 2800 to 6000 depending on the make and model of your SWG. At 3500 ppm, the salt can be tasted, but is not overpowering, and does not really leave much of a residue on your body. Living next to the ocean I imagine you know the residue the sea leaves on your body. I am not a fan.
    I would think the higher concentration of salt would be much more corrosive as well.
    Jul 2007
    Brisbane, Australia
    874
    there are models of SWG which work up to 35% of salt
    salt can be tasted at sea, and people usually don't have a problem with it, hundreds of millions people swim in sea/ocean regularly and some pay lots of money for the privilege.
    if the pool is built using suitable materials then there won't be any issues, especially given that the house is so close to sea anyway
    it's purely a matter of personal taste, and sea water can be diluted with fresh water to give any desired concentration
    Apr 2009
    Lima , Peru
    19
    using sea water is not an option(it will be to hard on everything) when I get the SWG I will not be dumping the pool water very often .
    What i do have is well water I will get it analyzed it will be a bit brackish (not always) but probably have allot of nitrates and phosphates .
    if you look at this satellite image I own the whole rectangle up to the road , you can see the top of the well.
    http://maps.google.com/maps/ms?msid=216 ... 9,0.007939
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    360
    "had to use a bulldozer to knock down the dunes and level the area and build my own 3oo ft foot road"
    WOW! In the US if you did that, by the time you got out of prison you'd be too old to swim!
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    Apr 2009
    Lima , Peru
    19
    Quote Originally Posted by Vickery
    that is the privilege of living in a third world country, 50 years (or more) ago you could do in the US no questions asked, look at all the old beach houses they are right on the water, even in Hawaii same thing
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Quote Originally Posted by lazzua
    I imagine if you filled the whole pool with the well water it might get VERY brackish huh? Just asking.
    Jul 2007
    Brisbane, Australia
    874
    another thing you could do is get a flow through pool. pump your water from the sea into the pool and back out straight away. if you are the only one swimming in it you probably won't even need chlorine. would fall into same category of solutions as knocking down dunes
    Apr 2009
    Lima , Peru
    19
    We did not bull dose all the way to the beach and really it was not sand dunes for the road to the house all the sand dunes are all untouched in front of the houses they are great protection from the wind. see this pictures when i built the road and the other two are the dunes on the beach http://www.mancoraperu.com/construction.htm
    No way would pipe anything on the beach we built 50 meter from the highest water tide of the year. In Hawaii the law is only 50ft (less than 13.5 meters) from the high tide mark, I know I have a house there and built a pool there. So we did not do any damage to the beach as you can see in the photos.
    Robins Airman's Avatar
    Jun 2010
    Bonaire, GA
    139
    Lazzua, just curious...are you an expat living in Peru? are you a builder by trade? your beach house set up is my dream retirement location...i have always saw my self retiring in a setting just like the one you own...except i realize that is not going to be affordable in the states.
    Man you got it made!
    Thanks...Bo
    Thanks all for your amazingly helpful advice! Bo
    18x33 Morada pool, 14,100 Gal - 2HP, 2SPD W/Skimmer and Caplet Basket, 125 GPM Waterway ProClean Cartridge Filter System – 8 Gal LQ - TF-100.
    Thanks in advance for all your help!
    God Bless America!
  20. Back To Top    #20
    Apr 2009
    Lima , Peru
    19
    Quote Originally Posted by Robins Airman
    Thanks...Bo
    no was not a builder but since semi retiring have started bulding on my own. the house you see in Peru I built with a local crew in 6 months. all concrete block , one solid slab foundation one pour 12" deep and sides 24" deep uilt like granite. the whole house sits on it. all type V cement as we are so close to the ocean, same as the pool one pour 1/2"rebar all type V cement.
    I could go an on but the topic is SWG and this week will decide on which one as there are not many choice after 50,000 gallons.
    Basically that I can see these are my options:
    A. autopilot RC52 or CC15 $1500+
    B. IntelliChlor IC60 $970
    C. CompuPool CPSC48 $750
    D. is there anything else I left out whast about the autochlor brand from AU??
    Do not know if I am allowed to put the prices or not if I did wrong please delete prices.
    this is decision time any last comments would be helpful
    thank you LAZZUA
