Thread: Complete drain and fill
    Hi all,
    New user here. Been reading for the last week+ Lot's of great info. I just did a complete drain and am refilling our plaster/concrete pool. At the rate it's filling it should be done sometime tomorrow afternoon. The pool was setup as a chlorine pool and will probably remain as such unless there is a good reason to convert.
    I looked on the board but didn't see anything that specially was to a drain and fresh fill (off municipal water) for a chlorine pool. What are the steps and order I should do them in to get the pool ready for summer?
    Thanks in advance and for all the interesting reading over the last week.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Complete drain and fill
    Ignore the "Seasonal/Temporary" part. Same rules apply. pool-school/temporary_pool_guide
    Welcome to TFP!
    The first thing is to get test results for PH, TA, and CH. Also, add 2 ppm of chlorine the first evening, and start adding CYA.
    Thank you for the quick replies. I'm still kind of new to being a pool owner and maintaining it myself so I really glad I found this site.
