Results 1 to 11 of 11
Thread: g.a.m.e. Sand Pro 3/4 HP Sand Filter System - any good
    20GT's Avatar
    May 2011
    Orlando, Florida
    50
    Hi all
    I'm looking at getting item#35414101 Sand Pro 3/4 HP Sand Filter System
    (Mfg # 4511 ) from pinch a penny.
    Do you think its worth it. I have a 5500gallon 15' intex (1"diameter pool hose)
    can i also add a cartridge filter to that later?
    I also have a pool hose i got from Walmart and a vac head whats the best way to hook that up?
    5,593 gallons of water at 80% capacity <Orlando, Florida>
    AG Intex Round Metal pole Swimming Pool - 16 Feet x 48 Inches (Intex A 16 X 48 F B02 11 01)
    Sand, SandPro 75 – 3/4 HP, 45GPM/2700GPH flow rate. GAM-4511 (Just days old 7/5/11)
    Crystal Clear Still
    Jun 2011
    Albuquerque, NM
    77
    Re: g.a.m.e. Sand Pro 3/4 HP Sand Filter System - any good
    I have this for my pool. Of course it has only been 4 days of use, but so far no problems with it. We did have some issues of sittin the hoses perfectly so they didn't leak; thy don't give you much space to work with. But it's easy enough for me to use. My pool is a bit smaller than yours, but it's working well with keeping my pool clean.
    Cindy
    4.8 K gallon AGP: sharkline opera 12'x17'x52"
    Sandpro 4511 sand filter and pump
    20GT's Avatar
    May 2011
    Orlando, Florida
    50
    thanks for your responce,
    we bought it going to get it Tuesday.
    Did yours come with sand? or some other media? whats the best?
    Were the inlets and outlets the same size as the old rinky dinky one that came with it?
    Crystal Clear Still
    Aug 2007
    near the swamp
    806
    I haven't had any issues with these units yet. They seem to be well built. GAME said they used to use them on small ponds.
    No they don't come with any sand, you'll have to buy that separately. 78lbs is what it holds.
    Jun 2011
    Albuquerque, NM
    77
    You need to buy the pool sand. Ours were 50 lb bags, so it took approximately 1.5 bags. Still no problems with ours. We run it enough to turn the pool over about twice a day, adds to a couple of hours during the day and a couple at night when I add the bleach. I don't have an intex pool, but there were some additional parts that are supposed to fit your pump and filter to the intex connectors. So I would guess it would not be a problem.
    Cindy
    20GT's Avatar
    May 2011
    Orlando, Florida
    50
    thanks. does anyone know how i would hook up the vac i pieced together from Walmart.
    I suppose that's done from inside the pool.
    i going to look for some pvc that matches the pool screen intake and output (the part that goes thru the wall) that came with the pool.
    Crystal Clear Still
    Aug 2007
    near the swamp
    806
    http://www.game-group.com/products/wate ... pter-tube/
    Those? Your local Pinch A Penny should have them in stock, if not they can get them for you.
    20GT's Avatar
    May 2011
    Orlando, Florida
    50
    yes. thank you. that looks great.
    any ideas on a bottom drain? no holes piping it in
    Crystal Clear Still
    Aug 2007
    near the swamp
    806
    no sir, that sounds impossible
    22,553
    You could run a pipe over the wall of the pool and down to the bottom, kinda like a reverse snorkel, but I'm afraid it'd be in the way all the time.
    20GT's Avatar
    May 2011
    Orlando, Florida
    50
    i figured i'd just use the vac inlet to connect a pipe down the wall and over. that way i could disconnect it when needed.
    Crystal Clear Still
