Thread: CC never 0
    CC never 0
    My last test results were:
    CYA - 40
    FC - 6
    CC - 0.5
    CH - 100
    TA - 90
    pH - 7.5
    Every test I have done with my TF100 I have had a CC of 0.5. Anything under 1.0 is fine, but is there a reason that I would always have 0.5, and never 0?
    76549 Liters -- Cartridge Filter -- In Ground -- Vinyl -- TF-100 Test Kit -- AquaVac Robotic Cleaner -- UV Sanitation -- Winter Safety Cover -- Installed 2010 -- Southwestern Ontario, Canada
    Latest Test Results June 25:
    FC - 6, CC - 0, CYA - 40, CH - 110, TA - 90, pH - 7.5
    30,431
    Re: CC never 0
    That's completely common....my pool is the same.
    Treat .5 as if it were zero....that's why we suggest .5 or less as the standard.
    Re: CC never 0
    I didn't know if it was a situation were 0.5 is good, but 0 is optimal and preferred. I am using the BBB method and it is dummy proof so I thought maybe this was an issue I was having. It's good to know this is normal. Thanks
