Thread: Pool Heater - What is the typical water temp increase?
    Jul 2009
    Eden Prairie, MN
    37
    Heater is an older Raypak RP2100.
    Water Temp in 77F
    Water Temp out 86F
    Does this seem right? Thanks.
    AGP partially buried, with surrounding deck and flower bed. 12 x 24 oval x 48" deep Celebration by Forum. Steel sides, vinyl liner. Hayward 2 HP sand pump. Flower fountain - works well to cool water up to 10 degrees.
    Ft Lauderdale, Florida
    1,455
    Re: Pool Heater - What is the typical water temp increase?
    9 - 12 degrees difference on a gas heater is normal. Lower than that means too much flow going through the heater. Higher than that usually means low flow. There are issues with too high and too low flow conditions, which should be explained in your owners manual.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
