Thread: switched from using Baquacil to Clorine
    About a week ago i started my transition from using Baquacil to Chlorine and I think I have all the Baquacil products out because my Chlorine levels are high and remaining that way. But my levels in pool are out of whack and I need help figuring out what to add in pool, the people at pool store give me stuff I do not need...!!! Here are my 6-way test strip calculations:
    Total Hardness 400
    Free Chlorine 10/20
    ph 8.4
    Total Alkalinity 80
    Cyanuric Acid 0
    My pool is a 4400 gallon Intex Pop Up Pool
    Thank a bunch any help is GREATLY appreciated
    Columbus Ohio
    178
    Re: switched from using Baquacil to Clorine
    Well, you need to bring down the PH to around 7.2- and raise your CYA to around 30!
    Purposed new pool at home being built- 20x40 vinyl pool, 20ft vinyl covered steps, Automatic cover, 6 ft sheer decent, 4 lighted deck jets, lime stone coping, easy touch, heat pump, SPA- 8x8 fiberglass shell, limestone steps surrounding
    previous home- 16 x 32 IG Vinyl- Install- Mid June 2011. 3ft Shallow 8ft Deep/ Totally Hayward 1HP pump/ 250 pound Sand/ AquaPro800 Heat pump/ Blue Hampton Liner/ 2 Intellibrite LED Lights/ Polaris 360/ 4 Deckjet II's/ 3ft concrete Apron/ 800 sq ft Paver Patio
    What do i add to do the ph?
    The best thing to lower PH is muriatic acid, available at most hardware stores. You can also use dry acid/PH Down sold at pool stores. Dry acid is more expensive but simpler to handle.
    Depending on how high your FC level really is (I'm not sure what 10/20 means) the PH test results might not be valid. Any time FC is higher than 10 you should ignore the PH reading until the FC level comes down to something more reasonable.
    Have you seen our Baqua to Chlorine Conversion Guide? It is best to follow through all of the steps in there to make sure your conversion is complete.
