Thread: Working on the water lines with a full pool?
    Hi everyone,
    I need to work on the tigerflex around the jets of the pool, however the pool is already filled.
    I was wondering if there was a way to plug the jets from the pool side, and turn off the equipment so that I could temporarily drain the lines and do some quick reconfiguration on them. I really want to avoid draining the pool if at all possible.
    Thanks everyone!
    Adam
    12'x23' | 8,400 Gallons | Fiberglass Pool
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Working on the water lines with a full pool?
    Welcome to TFP!
    You could just put winterizing plugs in them.
    or
    Brilliant! Thanks for the tip and the welcome.
    I'll post back and let you know how it went.
    Adam
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    If you can't find those plugs, carefully measure the holes and head for an auto parts store. They sell rubber freeze plugs. Same principle, maybe not as deep. http://www.dormanproducts.com/c-354-exp ... ubber.aspx
