Results 1 to 12 of 12
Thread: Problem adjusting PH
    I tried adjusting PH 3-4 times this season, but it climbs back to 7.8 in a couple of days.
    My TF kit from last year shows TA at 100. Leslies Taylor 70, 80, 90 (depending on the store). I found a Leslies employee I like and watched her do it twice - both times I counted 7 drops myself.
    I keep my TF kit covered in the box it came in (plastic + cartoon). Kit was in the garage over the winter, where the temperature was above freezing, may have dropped to 32 once or twice but I doubt it. (I monitor temp in the garage - have water pipes there)
    Could my kit go bad or is leslies Taylor over concentrated?
    Can "Ph Down" ("pool time" product from home depot) have an expiration date? I used it all already, and just now added some "Ph Down" ("aqua chem" product from target). Both products were purchased last year
    I use liquid chlorine, my other parameters are within range and I have not done any work with the pool surface (concrete).
    please advise.
    P.S. (919) 528-1104 - TFTestKits.com contact number is occasionally out of service. I tried calling 4 times, 3 times I got an "out of service" message
    Bill
    18'X4' 7600 Gal AG
    3/4 HP Pentair Pump
    Hayward S166T 100 lb sand filter
    Sep 2009
    Greentown, IN
    914
    Re: Problem adjusting PH
    I would try to keep adjusting it down and see if it settles finally. Can't tell you if I'd agree w/your kit or Leslies... How many times did you do the test yourself?
    If you have any active aeration... a waterfall, swg, or splashing in the pool it can cause your ph to rise regularly.
    Have you had a lot of rain? That can aerate and add/change the chemical balance a bit if you've had enough.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Quote Originally Posted by Suziqzer
    3-4 times. Every single time I get 10 drops
    Don't have that
    We did have a few rains this season, but I thought rain brings Ph down, not up.
    Bill
    18'X4' 7600 Gal AG
    3/4 HP Pentair Pump
    Aug 2010
    Dallas, TX
    4,052
    I've had rain swing my pH both ways. It baffled me too!
    You know you can use muriatic acid to lower pH, right? You don't have to buy from the pool store.
    If you continue to have wildly swinging pH, you might be a candidate for adding borates.
    Quote Originally Posted by RobbieH
    I don't know the difference between muriatic acid and "Ph down" products, but I got my aqua chem "Ph down" from target when they had it on clearance, $2 for 5LB, which I figured is pretty cheap.
    I'll have to read up on this - know nothing about it. But first I want to make sure my TA is within range. I was able to get a hold of an answering service for tfkits and now waiting for a call back. If my TA is indeed out of range, I guess I'd need to adjust it first before I try anything else.
    Bill
    18'X4' 7600 Gal AG
    3/4 HP Pentair Pump
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Duraleigh and his wife own TFtestkits.net. He also happens to own TFP, so if there is an issue with the phone, you can certainly PM him. Dave is a great guy with an excellent customer service record.
    If you PH is rising rapidly and the pool has a saltwater generator or source of aeration, such as a spill over spa or waterfall, you may consider lowering TA to 60. Borates at 50ppm also slows the rate of PH rise, so you'll still need to add acid just less frequently.
    Aug 2010
    Dallas, TX
    4,052
    You are correct by the way, make sure your TA is correct before adding borates. It's far more difficult to adjust once borates are in.
    For what it's worth, I don't consider your TA range of 70-100 to be bad.
    Mar 2011
    Houston, Texas
    413
    FWIW, my pH test from the TF-100 and a slightly older Taylor kit I had before I bought the TF-100 both show pH a little higher than the pool store's tests. The stores are usually 10-20 lower. This can be a problem for me with my constantly rising pH and rising CH. The difference between 110 and 90 TA significantly changes the CSI.
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
    I think I may have figured it out. It seems like liquid chlorine has a Ph at 13. If so, how do I calculate how much Ph I'm adding with 1 gallon of chlorine?
    Bill
    18'X4' 7600 Gal AG
    3/4 HP Pentair Pump
    30,431
    You aren't adding any. LQ is virtually net PH neutral and will have little if any affect on your pH.
    Please PM me and let me know when you tried to call. We had a 1-2 hour power outage a few days ago and our wireless phones weren't available to us during that period. That's the only time I can think of.
    can eyeball direction cause PH climb then? they were pointing up slightly but there was no bubbling
    Bill
    18'X4' 7600 Gal AG
    3/4 HP Pentair Pump
    Lots of things can cause the PH to rise. With TA at 100, rain will tend to raise the PH, people swimming, plaster applied in the last year, a bunch of things.
