Thread: Still messing with this pump....
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    Ok I'm having a helluva time getting my pump to prime. It used to be occasional but now it's every morning. I have to pull the lid of, fill the pot with water and repeat - sometimes many times before it will prime. In the pic below, the faucet right above the fault definitely has a leak. I gotta figure out how to get the faucet loose and replace the part. I've never even used that faucet so I don't think it's necessary. My question - is there anything else on the cheap I should tackle while I got this taken apart?
    Brian
    20K IG Gunite w/ raised 7ft spillover spa. 1.5 HP Hayward Northstar pump 425 sq ft Hayward cartridge filter, Colorlogic lights AquaRite SWG AquaLogic PS-8 control
    1hp pump for sheer descent
    Re: Still messing with this pump....
    The pump losing prime usually means an air leak on the suction side of the pluming. However, if it only loses prime while it is off, that could be caused by a leak on the pressure side of the plumbing.
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    Thanks. Do you know how to get that faucet off? Can I seal that seem where the faucet fits into the "T"?
    Brian
    It should unscrew, although they may well have used locking thread sealer, in which case it won't unscrew at all easily. If it does unscrew without damage you can get a plug with the same kind of threading. If it doesn't unscrew, or there is damage, you will need to replace that section of pipe.
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    I decided just to cut it off before the T and install it all new. It was VERY easy to do. I'm not intimidated by electrical stuff but plumbing makes me nervous due to my lack of experience. I let it sit for a couple of hours and turned the pump on and it primed immediately. <crossing fingers!> Thanks for the tips
    Brian
