Results 1 to 12 of 12
Thread: Pool Slope Questions
    Jun 2011
    Frisco, Texas
    70
    I am trying to determine if I should go with a 6 feet or 8 1/2 feet deep pool. It will only be 33 feet long and 22 feet wide. My preference is to go 8 1/2 if I can. Will the slope on the pool be to much if I start it out at 3 1/2 feet? How many feet can I have in the 3 1/2 to 4 1/2 feet range then start to drop? I'm sure that there is some ratio to determine the drop. For some reason most builders do not want to go in between 6 feet and 8 1/2.
    I have 2 boys 6 and 8. I don't plan to get a diving board. But would let them jump off a jumping rock that will be 3 feet off the water.
    33'x21' In-ground (23,000 gal) - 8' spa raised 18" with 8 jets | Filtration Jandy DE 60 | Sanitation Aquapure 1400 SWG | Pumps Intelliflo VS+SVRS 3.0HP & Jandy 1.5HP stealth water feature pump | Heating Jandy LRZ400 | Lighting Jandy LED Spa (1)/Pool (2) | Coping Tennessee Crab Orchard & Moss Rock | Finish pebble sheen type (riversand) Tahoe Blue
    30,415
    Re: Pool Slope Questions
    Your state will have some building codes that will dictate what you can build. I will say that a pool that size going to 8.5 feet will not have much of a shallow end.
    22,548
    In a pool 33' long, you're either going to have a very small deep end (which defeats the purpose) or a very small shallow end. There's a guideline for the max slope a transition can be, so that's pretty much set.
    To me the ideal pool is shallow on each end and about 6' deep in the middle with rolling slopes.
    Feb 2011
    Petaluma, Ca
    665
    I believe the legal ratio is 12" of drop for every 36" of distance.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    May 2011
    Montgomery, TX
    176
    msujohn, are you having a diving board in the deep end? that's the only thing i'd want to go that deep for. i am having a 18x36 pool installed right now and it goes from 3.5-7ft and i think it's just right. i have no diving board just a small jump rock in the deep end.
    Jun 2011
    Frisco, Texas
    70
    I am not having a diving board - I am having a jump rock as well. But the builders will only build a 6 feet or 8 1/2 feet deep pool. For some reason, they will not go to 7 feet deep. I was hoping that I would be able to have some room to play volleyball as well, but that doesn't look like I can do that.
    May 2011
    Montgomery, TX
    176
    Quote Originally Posted by msujohn
    just reread your original post. with a 3 foot high jump rock you might want to go that deep. it would make the slope much less if you could lengthen the pool a few more feet.
    Columbus Ohio
    178
    I just had a 32X16 installed, the slope is a 14. It left 8 Feet of shallow and the rest is into the deep end.
    Purposed new pool at home being built- 20x40 vinyl pool, 20ft vinyl covered steps, Automatic cover, 6 ft sheer decent, 4 lighted deck jets, lime stone coping, easy touch, heat pump, SPA- 8x8 fiberglass shell, limestone steps surrounding
    previous home- 16 x 32 IG Vinyl- Install- Mid June 2011. 3ft Shallow 8ft Deep/ Totally Hayward 1HP pump/ 250 pound Sand/ AquaPro800 Heat pump/ Blue Hampton Liner/ 2 Intellibrite LED Lights/ Polaris 360/ 4 Deckjet II's/ 3ft concrete Apron/ 800 sq ft Paver Patio
    I originally was gonna get a 16x32 with a 8 ft deep and but ended up with a 15x30 6 ft deep and Im glad I did.I can still bounce around in the deep end with a drink.
    Jun 2011
    Frisco, Texas
    70
    I don't have the ability to go any longer than 33 feet (my yard is limited). So trying to decide if I can live with very little shallow end or just go with a 6 feet deep pool.
    22,548
    Those 6 & 8 year old's are gonna spend the next few years mostly in the shallow end. I'd go less deep and more of a shallow end.
    Mar 2007
    Houston, TX
    167
    Also remember if your deep end is in the middle, both ends will have a steeper slope to the middle and might be less comfortable to stand on. If your deep end is on one end, the slope will be more gradual and give you more usable space for the kids.
