My pool has been looking great, but it is starting to take a cloudy turn. I have added the recommended MA, but my numbers are not changing.
About three months ago we had a new liner put in and I installed an Intelichlor IC40 SWG. My fill water has very high PH, so I went ahead and stocked up with MA. I have added around 4 gallons of MA over the last month or so typically a gallon at the time and my PH and TA will not come down. None of my returns are breaking the surface of the water, so I am not aerating... I don't know what is going on.
I am currently running my pump around 12 hours a day and my pool has direct sunlight from early morning until late afternoon. Current water temp is 90. I know my chlorine is low and will change my schedule to run longer to compensate.
I also test with a Taylor 2006 kit and my numbers are listed below. Any suggestions are welcomed.
FC = 1
CC = 0
PH = 8.0 + (very pink)
TA = 200
CH = 50
CYA = 60
Salt = 3200
FC = 1
CC = 0
TA = 200
CH = 50
CYA = 60
Salt = 3200
