Thread: Ph Level
    Apr 2010
    Western North Carolina
    44
    Ph Level
    I have two quick questions. While water testing a minute ago, I found my PH was in the 8.2 range.
    1st Question: Would my teenage daughter and her friend covered in sunblock or tanning lotion raise PH?
    2nd Question: Does Muriatic Acid go bad or weaken? I have had some since last year and it has been stored in my basement.
    As always, thanks for the help!
    24' X 52" AGP - On a concrete slab with 1" Dow blue foam board bottom.
    2Hp 2 speed Waterways pump/Cart. Filter.
    Hard Plumbed 20' away
    Deck 1/3 around pool
    Pool Rover Jr.
    DIY project
    Best Pool Store Quote, "THAT BLEACH WILL DESTROY YOUR LINER."
    Re: Ph Level
    People swimming can cause the PH to go up because they cause aeration. Neither sun block or tanning lotion will raise PH.
    Muriatic acid will last a very long time, certainly way more than a year.
