Results 1 to 8 of 8
Thread: CYA Testing
    May 2011
    Charlotte, NC
    9
    CYA Testing
    Is there any better CYA test than watching the black dot disappear? Seems to produce some variance, maybe just in my head?
    15000 Gallons FiberGlass Ingound Sandfilter W/SWG
    Re: CYA Testing
    The black dot test is the best test available. There are other tests that give more direct readouts, but they are actually much less precise.
    If you are not confident in your reading, you can pour the solution from the view tube back into the mixing bottle and then try filling the view tube again. You can repeat this portion of the test over and over again for several minutes without affecting the test results.
    Jun 2011
    Mississauga, Ontario
    6
    Re: CYA Testing
    Didn't know that. Thanks for the tip.
    Cheers
    lazy L vinyl salt water inground pool (24,767 US Gallons)
    1HP Pump Sta-Rite Max-E-Pro Pump
    300 sq ft Sta-Rite Cartridge Filter
    May 2011
    Charlotte, NC
    9
    Re: CYA Testing
    Thank you for the info, and it is when the black dot "completely" disappears?
    Re: CYA Testing
    Yes, you want the black dot to completely disappear. There should be no hint that it was ever there, even when you stare at the sample for several seconds. The test should be done in sunlight, with the view tube shielded from direct sunlight by your body.
    May 2011
    Charlotte, NC
    9
    Re: CYA Testing
    Thank you very much Sir. Those little tips will really help, as simple as they seem I think they will make a difference!
    Re: CYA Testing
    There is a lot more along the same lines in the Extended Test Kit Directions topic.
    Montreal Canada
    326
    Re: CYA Testing
    It may be worthwhile to look into Costco's LED reading lamps. These are little LED reading lamps, 2 per pack, with a huge clip at one end and 3 LEDS at the the other end, whose brightness can be adjusted. The aluminum gooseneck can bent and be adjusted exactly where you want light to shine.
