Thread: Do Borates taste bad?
    SW Georgia
    300
    My family has been complaining that the water in our pool taste bad. This only started happening since I added Borates. I have to agree that the water does have a different taste than before but since I take care of the pool and Borated help me do that I can get use to the different taste. I was just wondering if anyone else has noticed this???
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
    Aug 2010
    Dallas, TX
    4,052
    Re: Do Borates taste bad?
    I would say it's slightly different, but very subtle. Nobody has ever said anything to me about it. I don't make it a habit to drink it though.
    I didn't notice any difference after adding borates. Adding salt gave it a slight salt taste, but borates didn't seem to do anything.
    Mar 2007
    San Rafael, CA USA
    12,082
    According to this link, boric acid "has a slight acidic, bitter taste and sweetish after taste." However, I believe they are referring to the powder and not diluted boric acid in water and generally the acidic bitter taste is attributable to low pH which is not the case with pool water.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I did notice a slight bitter taste when I first added the borates, but it's gone away or we gotten used to it now.
    chiefwej
