Thread: Pool Hoses
    Pool Hoses
    I currently have an above ground pool surrounded by a deck. I run the hoses under theck about 15 feet to the filter. Everything seems to be runnign correckly. I am using the cheap hoses that came with the pool, but one seems to have a very small leak. What is a good strong hose to run under a deck?
    Semi above ground pool 12x16 raypak 156a heater
    22,542
    Re: Pool Hoses
    Most people around here that have problems with the hoses go with either flexible PVC or hard PVC for the plumbing and get rid of the hoses all together. That would be my recommendation.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Re: Pool Hoses
    Agreed, if you don't want to hard plumb buy flexible PVC, that stuff seems indestructible (costs a few bucks, where I live anyways)
    Re: Pool Hoses
    how to I connect the flex pvc to the filter, motor and pool intake and outtakes? Right now I have the metal clamps.
    22,542
    Re: Pool Hoses
    You'll use glued and threaded adapters to connect the equipment ot the piping.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Re: Pool Hoses
    Your pump should have come with male/female ends for pump intake, filter outflow and skimmer/return, and metal clamps to tighten the hose to the ends.
    Get the flex PVC, cut to length, screw the ends into all the proper places (with plumbers tape or similar product) insert ends into the flex pvc and tighten with the metal clamps.
