Thread: Sulfates why so bad?
    Pool-creetin's Avatar
    Mar 2010
    Michigan
    181
    I see dry acid is discouraged here for its sulfate content. Why is that? Does not sulfate and chloride ions cancel each other out at the end point?
    Just trying to get a better understanding.
    26x16 rockwood keyhole vynil inground, waterway cartridge filter and swg, variable speed pentair pump, extra large skimmer with 2 main drains in deep end and 2 returns,Rheem raypack 206 natural gas heater, hayward tigershark qc robot. Being installed in late may early june. Woot!
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    Re: Sulfates why so bad?
    Here is a good article on why you should not. http://www.pwtag.org/TECHSulphate%20Attack.php
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    Mar 2007
    San Rafael, CA USA
    12,082
    [EDIT] This link fixes the one above that is now broken. [END-EDIT]
    That's a great link/article. Thanks for posting it. It's one of the few references that gives a maximum limit (300 mg/L) for sulfate levels in pools. As for references on sulfate attack on cement and concrete, there is also Sulfate attack in concrete and mortar, Mitigating Sulfate Attack, External Sulfate Attack and Sulfate attack on cementitious materials containing limestone filler as well as a variety of articles on sulfate-resistant cement and concrete. This report goes into more detail about the mechanisms for sulfate attack in concrete.
    Aug 2008
    Fredericksburg, VA
    51
    Quote Originally Posted by benavidescj View Post
    That site has evidently moved that article. Here's the new link.
    20,000 gal. free-form plaster on concrete
    Triton DE filter, 1.5HP pump
    Aquabot Elite pool cleaner
