Results 1 to 16 of 16
Thread: Need help with Green Algea
    Jun 2011
    Cape Girardeau, Mo
    125
    Have been battling green algae for about 3 weeks now i started shocking it and it started to clear but it seemed like my pump and filter that came with the pool just couldnt keep up so i ordered a Intex sand filter 16'' 2650 gph and installed it on Saturday. I have a Taylor K-2006 test kit but used the last of the Dpd powder today ordered more it is on the way so my levels from today are as follows.
    TA 100
    PH 7.2
    OTO 7.5
    FC 5,5
    CC 2.0
    CYA 40
    I am using liquid chlorine 10% and have plenty on hand this afternoon i added 60 ozs to try and get the level to 16ppm..any advise for my swamp?
    Thanks ....Steve
    Steve Frakes
    15' X 48'' Intex Metal Frame
    Intex Sand Filter 16'' 2650 GPH
    Taylor K-2006 Test Kit
    BBB and Borated
    38,271
    Re: Need help with Green Algea
    Sounds like you have the right testing kit ... just need the powder.
    Read pool-school/shocking_your_pool and Pool School if you have not already while waiting for your powder (although it seems like you know what you are doing at least a little by stating you are shooting for your shock level of 16 ppm.)
    Remove any debris on the bottom of the pool and keep adding FC to stay at shock level and it will clear up.
    3 weeks seems like a long time so either the FC was not as high as it should have been and/or the circulation and filtration was not working properly.
    With CYA at 40, shock level is FC at 16.
    Jun 2011
    Cape Girardeau, Mo
    125
    If i mantain the free chlorine at 16 how long before i should be seeing a differance in appearance ?
    Steve Frakes
    BBB and Borated
    Usually there is a change in the shade of green to either a duller green or a gray color in a couple of hours, but making sure you killed all of the algae and clearing up the water can take days to almost two weeks, since the filter still needs to filter all the debris out of the water.
    The best way to see how you are progressing is to do an overnight FC loss test. If you are still losing chlorine overnight then you haven't been adding enough chlorine. But if overnight loss is minimal and the water isn't improving day by day then there might be something wrong with your filter.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    I would imagine that if you actually maintained 16ppm, some kind of change should be noted within a day or so... something (not clear of course, but not the same dark green you show in the image).
    But maintaining shock level requires some vigilance and very frequent testing and adding chlorine. Algae like that will eat up chlorine quickly, so every hour or two you will have to add bleach to keep it at 16ppm. Eventually this should come to some kind of balance where less and less chlorine is lost over the hour or two that you wait, and at that point something should start to change that you can see. I've got a feeling that while you've been adding chlorine a lot lately, the scale is tipped towards the algae's side because as soon as some is killed, the chlorine level gets too low for too long and it just grows again. Kinda like a zombie... Remember... Rule #2 - Double Tap.
    I read here that the sand filters aren't capable of filtering the smaller particles, and it could take longer to filter dead algae with that. We've had good luck with using an old 1000gph pump/filter as a secondary pump with the suction end weighted down to the bottom. I posted some pics recently here that shows the funky looking setup.
    full-time-pumping-intex-t33543.html
    Since you've still got the functional Intex filter, try adding that to the pool (doesn't have to be permanent, but right now it can't hurt) while you're waiting for it to clear. The paper filters actually perform better when they aren't brand new, some gunk on them seems to help catch particles that might otherwise pass through.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Jun 2011
    Cape Girardeau, Mo
    125
    Well thanks to this site and pool school i think we are on the way to a clear pool i can now see the bottom once again! I don't think i will ever walk into a pool store again except maybe once in awhile for some cya.
    Steve Frakes
    BBB and Borated
    Jun 2011
    Cape Girardeau, Mo
    125
    Seems to be getting better by the hour!
    Steve Frakes
    BBB and Borated
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Hot Diggity Dog!
    Jun 2011
    Cape Girardeau, Mo
    125
    Got my test refills in today and boy were the pool store off this weekend here are my results.
    CYA 70
    CC 0
    FC 14
    PH 7.4
    TA 210
    CH 225
    WATER TEMP 84
    Borate 45
    It is clear i can see the bottom but it is very slightly cloudy not quite sparkling like i would like . Could the alkalinity be making it slightly cloudy? It has passed the overnight chlorine test should i just give it some time or would you bring the chlorine back up to shock level?
    Steve Frakes
    BBB and Borated
    Butterfly's Avatar
    South Carolina
    10,045
    I'd take it back to shock level.
    You're done SLAMing when:
    Jun 2011
    Cape Girardeau, Mo
    125
    Thanks Butterfly i will do just that i know you guys swim at shock level !...So reassure me i don't have to kick the kids out at a shock level of 28 for a 70 Cya?
    Steve Frakes
    BBB and Borated
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by fsteve65
    Generally, we say swimming is okay between minimum and below shock level for your CYA.
    So, let it drop at least a little
    Jun 2011
    Cape Girardeau, Mo
    125
    After shocking one more time i woke up to a sparkling pool..Guess it just needed one more shocking .
    Steve Frakes
    BBB and Borated
    May 2011
    Clearwater, FL.
    446
    There you go! Make the kids do cannon balls and whirl pools to slosh out some water and with a little vacuum to waste and some water refilling you'll be able to get your CYA down some, 40-50 range works really nice for my 15'X48".
    I did also find that my pool likes the TA at 90, I did have mine up to 120 but I did have the PH swinging up all the time, now that I'm at 90 the pH stays right at 7.5 all the time.
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    Butterfly's Avatar
    South Carolina
    10,045
    Good job!
