Is the niche and conduit designed to be wet?
masand
May 19, 2010
31
Atlanta, GA
Sorry if I'm hijacking this post but think this is a related question.
Please ask questions in your own topic. JasonLion
Is the niche and conduit designed to be wet? In other words, in a proper install will there be water in the niche and part of the conduit (up to the water line)?
Re: Question about light wiring
My niche and conduit were wet and as far as I understand that is normal. Where the wires terminated is a good 2 feet above water level.
Welcome to TFP!!
In 23 years of doing pools, I've only seen "wet niches" which are supposed to have water in tehm - it helps keep the heat from the light from getting too high and tripping the breaker (however, if they make a wet niche, I assume there is such a thing as a dry niche :p )
waste said:
Welcome to TFP!!
There are dry niche lights. The only time I have seen functional ones are in really old municipal pools.
I thought the goal was to keep the conduit dry. In my niche it has a rubber bushing and nut that compresses to seal it. They also sell butyl to seal the conduit. With that said the only reason I would a need to seal it is if the conduit pipe (below water line) has a leak which could allow water to leak out of the pool. When I replaced my light a few weeks ago I sealed the conduit with butyl tape just for good measure. I see no downside of doing this.
Steve
If the light is designed to be serviced from the water side you want the conduit to be wet. You only use a dry conduit when there is access to the niche from the dry side.
Sealing the back of the niche is sometimes done, but causes problems later on. When the fixture eventually needs to be replaced the cable needs to be pulled out, which sealing the back of the niche usually makes impossible.
