Thread: AUTOPILOT DIG220 FAN
    Jul 2010
    Apopka, Fl
    31
    My DIG_220 Control box on the wall is very hot to the touch. I pulled off the cover and the fan is not running. With a little nudge the left fan comes on but the right one will not. Do thy come on at different temps or do I need a new fan?
    Inground 15x30 oval, plaster, 11250 gallons(?) with pool cage...jandy 100sq ft cartridge filter... SWG...Taylor K2006 Test Kit
    Located Apopka, Fl...Orlando area!
    Re: AUTOPILOT DIG220 FAN
    It sounds like you need two new fans.
    Ft Lauderdale, Florida
    1,455
    Older software versions had both fans coming on whenever the unit was energized. Newer Software has them coming on whenever the celll is activated.
    Therefore, you need new fans.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
