Results 1 to 19 of 19
Thread: Having our first real pool party this weekend.
    Jul 2010
    Mickleton, NJ
    229
    This weekend will be the first real pool party . We are expecting a few kids, in swim diapers, older kids and some rowdy adults. Should I bump the chlorine levels before or after the party or both? Also, since I'm a little paranoid is it an issue for the kids or adults to push off the sides of the pool when swimming?
    Currently Pooless
    Former Pool:Buster Crabbe resin and steel 30'x15' oval 52" ABG pool Pentair sand dollar filter 1.5 Pentair Dynamo pump13,500 gallons
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Having our first real pool party this weekend.
    I bump FC before and after
    You're done SLAMing when:
    Samantha_in_AL's Avatar
    Apr 2010
    Altoona, AL
    242
    I always ask that people do not push off the sides, or stand on/jump off of the top rails. I'm just picky like that. LOL
    Enjoy your party!
    AG 18' X 52" Round Pacifica Pool w/ Metal Diamond Unibead Liner. Installed in March 2007.
    2.5 HP Baquapure 2 Speed Pump, 200 GPM Waterway ProClean Cartridge Filter System.
    Former Baquacil user
    Converted to BBB in Fall of 2009 - Now I have a truly trouble free pool!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    What butterfly said on FC
    Sep 2009
    Greentown, IN
    914
    Ditto...
    and any other important rules should be mentioned prior to pool entry.... a few possibilities....
    No "p" in pool before swim... keep it that way.
    No diving
    Dry off before entering house (if that's important to you).. something we are struggling with, esp w/adults!
    No splashing pool owner if trying to lounge on raft.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Quote Originally Posted by Suziqzer
    I always liked "I do not swim in your toilet, so please do not P in my pool"
    Welcome to our OOL, there is no P in it and we would like to keep it that way.
    I've seen that and the swimming in your toilet sign before too. Those are pretty funny!
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Mar 2010
    Spring, TX
    1,082
    How much should it be bumped up?
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Quote Originally Posted by mynewpool
    Go look at the CYA/FC chart and set it up to the high end beforehand.
    And insist there's no glass near the pool.
    Quote Originally Posted by Richard320
    For a SWG, what FC should one bump up to for a pool party?
    Richard320's Avatar
    Jan 2010
    19,037
    Quote Originally Posted by anonapersona
    1300 posts and you still don't know that the target FC is always dependent upon the CYA level??? Tsk, tsk!
    20 lashes with a wet noodle!
    Oct 2010
    Georgia
    317
    With water temps in the high 80's and a CYA of 70 I normally see FC of around 5.5 with a pump run time of 8 hours
    Before a pool party I normally run the Aquarite for an additional 8 hour cycle to boost the FC to 6.5 or 7.
    I run the pump, filter and SWCG the entire time there are guests in the pool.
    After a large number of active guests are gone, I have seen levels as low as 3, but I simply run the Aquarite for an additional 8 hour cycle and by the next afternoon, the FC is back up to the target of 5. Within a couple of days, the water settles into it's normal FC of 5.5.
    The type of party and the type of guests will have a greater impact sometimes than the number of guests.
    I have noticed that with 6 or 8 adults lounging in the pool, a decrease in FC is rarely noted; however, with 6 or 8 active teens vigorously swimming, playing volleyball or basketball, diving, jumping, and generally having a good time that the FC can decrease by 2 or 3 ppm within a few hours.
    Your mileage may vary
    PSG
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
    Ouch, ouch! I've been noodled!
    OK, with CYA at 85, SWG goal is 4.0 and normal pool range is 7.0 to 12.0. So if the pool is at 4.0, and a party is planned, how far ought one bump up the FC in anticipation of, say a birthday party of 10 kids?
    Is there some FC drop per kid per hour that we can keep in mind?
    Anona, still the novice at SWG stuff
    Richard320's Avatar
    Jan 2010
    19,037
    Look up one.
    I think I'd do as you're thinking, and run FC up to bleach pool levels beforehand. That's all I know....I'm a jug-dumper.
    Oct 2010
    Georgia
    317
    With a CYA of 85 the target should be 6 with a minimum of 4.
    pool-school/chlorine_cya_chart_shock
    Bumping it up to 7 or 8 should be fine. It probably will be down to 5 or 6 after the party, but I would be very interested in your observations.
    "Is there some FC drop per kid per hour that we can keep in mind?"
    Still working on that one, but there seems to be some correlation between the last time the kid had a real BATH
    In the interest of science, please post your before and after pool party results.
    Thanks
    PSG
    poolschoolgrad
    30,426
    Jul 2010
    Mickleton, NJ
    229
    I'm the OP I don't have a SWG, I normally keep FC at 8, since my CYA is 70. I'll bump it to like 10 before the party. I'll also post results, of FC loss, for science purposes of course.
    Currently Pooless
    Oct 2010
    Georgia
    317
    melissa b
    Seems like a very good plan. Given the diversity in the age of your guests your pool seems like a very good test pool.
    I am sure a lot of regulars and lurkers will be interested in your results.
    thanks
    PSG
    poolschoolgrad
    Jul 2010
    Mickleton, NJ
    229
    The party was a success. The evening before the party I bumped the FC to 10, we got some rain in the a.m. but it quickly cleared to a gorgeous hot sunny day. I had 17 adults, 3 babies in swim diapers, 7 kids between 3-10 years old. The pool was full of people all day since our yard gets full sun from about 9:30 a.m. until sunset. About 10 adults were about back in the pool for a while after dark. The water was looking seriously cloudy at night. The next morning I tested FC was 5 and I had really poor circulation and cloudy water. Noticed pressure was high and were were almost due for a backwash. First I checked the skimmer basket which I knew had been knocked out of place during the party. I then checked the pump basket which was clogged with dead bugs. We cleaned it out and put it back, circulation got better. Next, we backwashed and circulation improved even more. I bumped FC back to 10 and then after a few hours dropped my hayward cleaner in the pool. As the day went on cloudyness improved and the pool got it's sparkle back.
    It was a great time, I was a little paranoid during the party about people just spraying sunblock and jumping right in, kids pushing off the sides, people drinking in the pool (cans) and then late night my rowdy friends started a whirlpool which was very impressive I must say, so much that the ladder was coming unscrewed from the pool and leaning almost sideways when I freaked out and told everyone to cool it. I tightened that up the next a.m. as well.
    Currently Pooless
