Thread: Adding accent tiles to pebble sheen
    Feb 2011
    Central Texas
    187
    How much of a PITA is it to add in some accent tiles to a new pebble sheen finish. I talk to my PB at the time about adding some accent tiles to the steps and benches but he talked me out of it. Now that it's done, I wish I would have had them added.
    IG 23K Gal, Quad DE 80, PebbleSheen, Intelliflo VS+SVRS, MT 400 NG, Stenner Pump
    Re: Adding accent tiles to pebble sheen
    It is difficult to add tiles after the pebble sheen is already in place and will never look quite right. To get a good edge between the tiles and the pebble sheen, the tiles need to be installed first and the pebble sheen applied right up to the edge of the tile. To put tiles in after the fact means chipping out sections of the pebble sheen and then patching the gap between what was chipped out and the tiles. But the patch will never exactly match and so will be fairly visible.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I wouldn't take a chisel to my finish, no matter what. It's just not worth it.
    Nov 2010
    Calera, Al
    271
    hindsight is 20/20... as MTIS Jason stated it would be an expensive project and still might not look good.
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    Feb 2011
    Central Texas
    187
    Yeah, that's what I figured.
    Oh well.
