Thread: Please Help!!
    Please Help!!
    I live in Louisville ky, have a 7800 gal above groud pool that uses cart. filters. The filter says is moves 1500 gal/hr.
    I have an intex saltwater system. It has been running 10 hours a day and the filter 24 hours a day for the last week. Ph is high, although i have added ph minus several times now (7lbs of it) , it is still 8.0. The free chlorine reads 0. Copper is normal, Alk. is normal. These are the only things i can test at this time. The water is very cloudy. what do i do?
    1) 10,000 Gallons
    2) Cartridge Filter
    3) IG
    4) Pebble
    5) Hayward NorthStar Self Priming pump and a Hayward Swimclear Cartridge Filter
    Nov 2010
    Calera, Al
    271
    Re: Please Help!!
    If you could post a full set of test results we can be of more help. but from what you have you need chlorine ASAP! have you added salt to your water?
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    Re: Please Help!!
    You really need a complete set of test results. If your test kit can't measure everything, get a pool store to test your water for you.
    Re: Please Help!!
    Yes I added 200lbs of salt a week ago. I will get one, just have not yet.
    1) 10,000 Gallons
    2) Cartridge Filter
    3) IG
    4) Pebble
