Thread: Diamond Brite
    Diamond Brite
    So we picked our PB and we are finalizing the contract. Wife and I sat down the other night to look at the Diamond Brite colors brochure. Was wondering if there are any colors to absolutely avoid? We are leaning toward "cool blue" or "blue quartz". We'd like to stay away from colors that darken the pool and limit the effect of the LED color changing lights.
    Let me know what you guys think.
    Thanks
    29' x 30' in-ground gunite, 20k gallons, superblue quartz finish
    IntelliChlor Salt Chlorinator
    IntelliPro VS+SVRS Variable Speed Pump (3hp)
    Pentair System 3 Cartridge filter (S8M500)
    2 skimmers, 3 wall returns, 3 floor returns, 2 drains
    StaRite Max E-Therm 400k BTU gas heater
    2 Deck jets
    SR Smith Turbo Twister slide
    Sep 2009
    Greentown, IN
    914
    Re: Diamond Brite
    Your location may be something to consider when you make a color choice. I know many in the south tend to choose lighter colors and those north go with darker .. either to avoid or capture the sun's heat. Just something to think about.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Re: Diamond Brite
    Quote Originally Posted by Suziqzer
    Suziqzer:
    Good point. Since we are up north (PA) might be something to think about. Thanks for the tip.
    2 Deck jets
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Diamond Brite
    To really see the colors in the lights, you need to go with a light color plaster. A solar cover will go a lot further toward keeping the water warm than plaster color (which I'm not convinced makes any real difference).
    Nov 2010
    Calera, Al
    271
    Re: Diamond Brite
    We have a blue diamond brite and also a colorsplash LED light. We love the baby blue carribean color to the water in the day and at night it shows all the colors of the LED well. Just make sure they do a through acidwash on the plaster to expose all the diamond brite so it will appear uniform and have no white splotches.
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    Re: Diamond Brite
    Thanks all...looks like we'll go with a lighter color - probably "Cool Blue".
    2 Deck jets
