How did you know??!! Thanks loads!!!!
I rechecked at 10 ml. I will make a permanent marker line on the 10 mL cylinder
FC 12
CC 0
I'm using 6% (182 oz jug)
I will be adding 3 jugs as per pool calc.
I'm actually happy that I underdid it. was concerned about ruining the vinyl etc.
I just discovered from a different discussion that I may have a prob with air in the system somewhere. apparently seeing bubbles from the return is not a good thing. who would've known. more things to dissect and learn. However I must say that every backwash is running green water so the filter must be doing its job.
Thanks so much for your help, I really appreciate it.
FC 12
CC 0
