Results 1 to 13 of 13
Thread: is irrigation water safe?
    Hey guys,
    I am trying to figure out a way to add some sort of auto fill option to my already completed pool. Our lovely builer obviously did not know that an autofill is a must when you have an infinity edge. The catch basin is about 18" deep (staying above wall suction lines) and is 17' long and 2' wide which by my calculations even with that all the way full, it will only raise my pool level 3/4" with my 650 surface sq footage and we lose about that from evaporation on a hot day.
    The easiest solution I can come up with is tapping into our sprinkler line that runs in our planters that are attached to the pool. That way im running a line 10" above the decking that can mostly be covered up by flowers. My question is, is it safe to you irrigation water as fill water daily? I have always been using my regular culinary water which is the same that comes from the kitchen tap. If its safe than I can just work it out with my sprinkler time to keep the water level close.
    If anyone has any other options of some how connecting into the equipment and adding water that way I am all ears. My infinity catch basin is almost always shaded so I want to run that on my daily program to keep an growth from happening
    Thanks
    18,000 gal ig salt pool krystalkrete plaster 7x10 raised spa w/ 2 spillovers
    4x20 wet deck, waterfall, 17ft infinity edge, deck jets, nexxus lighting
    Jandy pumps & controls, Aquapalm PDA, 400k heater, Kleen Machine robot
    (6) 4x12 solar panels, clear solar cover
    30,402
    Re: is irrigation water safe?
    Where does the water come from prior to it being in your irrigation system? Pond?
    Feb 2008
    Denton, TX
    5,061
    The water in my sprinkler system is the same water that comes out of my tap; city water. In fact, the fill valve is part of the irrigation system as a zone. Unless your sprinkler water is fron an untreated source, there is probably no risk in using it as fill water.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    As stated above, if it's connected to the same water supply as the house, which almost all are, the water is fine. When the sprinklers are on, do you hear water running in the house, like someone's in the shower? Then you're using tap water. Another way to be sure is to go pull the lid off your water meter, turn on the sprinklers, and see if the meter is moving.
    Connecting after the sprinkler control is dicey, if you ask me. Just guessing, but it's probably against the building code. Plus, batteries die, power goes out and timers revert to midnight, and those sprinkler control solenoids can fail. I'd look for where the sprinkler controls are and see if there is a way to tee in before the solenoids.
    You may just have to break out the pick and shovel. On the bright side, you'll have a nice pool to cool off in after you're done trenching.
    Mar 2011
    Lower Bucks County,PA
    65
    If you do find a spot for a tee there should be a backflow preventer installed on line to pool to protect main.
    12X24 Oval AGP +/- 7100 gal
    Clearwater 100 cartridge filter
    Hi-Flo 2sp 1hp pump
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Backflow preventer for sure! I would try to zone the pool on its own if I could. I zoned my on its own so I could add water whenever I needed it (I.E. after backwashing, splashout) and you don't have to water plants to get water in the pool.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Dec 2009
    Central Massachusetts
    2,690
    There's no backflow preventer need at all unless the sprinkler system itself doesnt have one which is highly unlikely.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    It is different water that what comes out of the hose and house. It is a pressurized irrigation lime owned by a private company that we have a share of. We just pay a flat fee for the 6 months a year it is active. Our neighbors say they have used it to fill true pool several times but I don't want to do something that is going to be a chemical nightmare or damage the filter
    Nov 2010
    Calera, Al
    271
    Quote Originally Posted by Utahjanitor
    If this is the case and I understand correctly it would only be of use to fill your pool for 6months of the year???
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    Yes. Our pool will be winterized the other 6. And really not even to fill the whole pool. More to add to the already full pool from evaporation loss. Which is about a half inch to 3/4 " a day
    Richard320's Avatar
    Jan 2010
    18,967
    If it's for irrigation, I doubt it's chlorinated, so there may be algae in it. Get a sample in a big white bucket. See if it looks clear. Take a whiff. Test it. Let it sit next to the pool for a day or two and see if it turns bright green.
    Then decide if you want it in your pool.
    22,539
    You can also use your TF-100 to test it. That way you'll know what you're putting in there.
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by maxepr1
    Definitely. Mine is on a separate zone and channel.
