Results 1 to 9 of 9
Thread: Must replace filter - getting differing size recommendations
    So my 300lb sand filter split down the side. When questioning various pool companies about a replacement, I am getting a wide variety of sizes being recommended. I think I am going to switch to a cartridge filter due to having to use so much hose to properly backwash because of the design of my property. When talking to several pool companies, I am getting most recommending a 420 or 520 Pentair. The 520 seems huge - do I need that large of a filter.
    I have an in ground saltwater pool that is approx 18000 gal. My pump is 1hp.
    I must make a decision very soon. Any advice is greatly appreciated.
    JR
    1) 10,000 Gallons
    2) Cartridge Filter
    3) IG
    4) Pebble
    5) Hayward NorthStar Self Priming pump and a Hayward Swimclear Cartridge Filter
    Re: Must replace filter - getting differing size recommendat
    Welcome to TFP!
    You don't have to get a large filter, you could get by with a 150 sqft filter. But if you can afford it, you will be happier with a larger filter in the long run. The larger the filter the longer you can go between cleanings and the more efficiently the filter will filter. We always recommend getting the largest filter you have room for and can afford.
    Thank you for the quick response!
    With all things remaining equal, does a larger filter reduce flow? Am I right in assuming that the 420 will still be significantly oversized for my application?
    Thanks again!
    1) 10,000 Gallons
    2) Cartridge Filter
    3) IG
    4) Pebble
    Voodoo_Pool's Avatar
    May 2011
    On the border AR/TN
    82
    Welcome to the Forum!
    I think this thread may answer your concern about filter size affecting (or not) flowrate: hydraulics-101-have-you-lost-your-head-t915.html
    According to Pentair, the 420 and 520 are both rated the same so getting the bigger filter will allow more time between cleaning.
    As Jason stated, bigger is generally better with regards to filter sizing.
    Enjoy!
    IG Vinyl 27,000 gallon "L" shaped (new vinyl April 2018) with spillway spa; Hayward 4820 DE; Polaris 380 w/ booster; TF-100 Test Kit w/SpeedStir
    Feb 2008
    Denton, TX
    5,061
    The 420 should be plenty for a pool your size. It's a great filter by the way.
    Great info! Thanks for the quick and informative replies.
    1) 10,000 Gallons
    2) Cartridge Filter
    3) IG
    4) Pebble
    Using a larger filter increases the total flow rate just a little because the larger filter has less total resistance to water flow. More importantly, since the water is spread out over a much larger filter area, the amount of water passing through any given patch of filter fabric is moving much more slowly and that allows the filter to catch finer debris that a smaller filter would catch.
    Awesome. The 420 is being installed today. Thanks again for the great and timely info. It got a little overwhelming with so many pool "professionals" offering different recommendations.
    1) 10,000 Gallons
    2) Cartridge Filter
    3) IG
    4) Pebble
    Quote Originally Posted by johnnyringo
    I installed a 420 this spriing...I love it !!!!
    22,000 Gal, in-ground ,vinyl. Pentair Intelliflo VS, Clean&Clear 420 cartridge, Hayward NG 300K heater, Polaris, EasyTouch,IC-40, (former Baquacil - converted to SWCG)
