Thread: Hayward drain valve assembly
    Hayward H series Drain valve assembly leaking. I am guessing the valve needs replaced (CHXDRV1930)--cost: 48.00 w/shipping
    Is there any reason I can't just put a $10 dollar plug in it and remove it at end of season for drainage?
    13.5k plaster, with raised spa and waterfall. Pentair VS Pump, Pentair cartridge filter, Pentair automation with 8 function EasyTouch remote. Currently using Rainbow 320, puck chlorinator. Liquidator on the way!
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Hayward drain valve assembly
    Welcome to TFP!
    I don't see why that wouldn't work...
