Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: Best robot for ~$1000???
    Apr 2011
    WPB, Florida
    51
    I been reading about these cleaners, but cannot decide on which to get.
    So far I have seen that the Polaris 9300 has quite a few followers. I also have a friend that has the Nitro wall climber and says its not too bad, like this one:
    http://www.intheswim.com/Pool-Equipm...-Pool-Cleaner/
    My pool has an 8'x24' sun shelf that is only 6" deep, wonder if the robots will clean that?
    What are your recommendations? Needs to have a 60 ft cord.
    J
    23K gal, in ground gunite, 2 HP Jandy pump, 200 sqft Jandy cartridge filter, Jandy SWG, Gulf Stream heat pump, Jandy Aqualink RS, 1HP air blower
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Best robot for ~$1000???
    I doubt any cleaner will clean your shelf...not sure though. From what I've learned around here, all the robots have their followers, but none are clearly better or worse than any other.
    Oct 2007
    Parkland, FL
    752
    Quote Originally Posted by Melt In The Sun
    not true, some are clearly better than others. ones that turn on the bottom of the pool are worlds better than ones that can't. if it can't turn on the bottom, once it gets a little clogged, it won't be able to climb the walls and will get stuck in the same spot.
    blue diamond for the price is probably best. Polaris bot is sexy and filter is cool but can only clean in one direction due to the patents owned by the makers of blue diamond and cobia.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    38,246
    I got the Dolphin Dynamic with remote control from Costco for about $1000 ... although they only offer it seasonally (not during the winter I saw). Nice because you can take control of it and drive it around in case it misses anything. I have read that the Maytronics support and getting parts can be a little problematic, but I had a bad power supply and had no problem getting it replaced for free. Does a great job picking up sand and dirt you did not realize was there. A little bit of work to clean the bags, but at least all the stuff is not going into my filter and you can buy disposable bags if you want.
    And of course if you do not like it, Costco is great about returns. I actually bought the TurboJet(?) that used water propulsion to move around from Costco too, but found that with a deep end ... it would quickly get stuck down there as the filter filled and propulsion was lost. Probably would be a nice unit for flat pools as it is very simple with few parts. No question when I returned it.
    Oct 2007
    Parkland, FL
    752
    Quote Originally Posted by jblauert
    I don't know how long the warranty is, but when the motors go on that, you can kiss it good bye, thats the problem with the remote controlled ones. not even anywhere near cost efficient to fix when it breaks (not IF, but when)
    I could have got a sweet dolphin remote for a little over 500 dollars refurbed, but no warranty means when it breaks, it will cost more than that to fix. of course the dolphin remotes are the only ones worth buying from dolphin because they can change direction on the floor.
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Quote Originally Posted by robl45
    I completely agree about the ones that change directions on the floor. I have a T2. I love it but the last few weeks I have a crazy problem where it wont climb the walls anymore. It is completely inexplicable. I changed the belts, and all other parts that wear out. The motor seems to be running great. But it wont climb a 90 degree wall even when the pool is 88 degrees and spotless. I think its the drive motor which would cost $500 to replace!
    Anyway thats not that big of a deal... I dont care if it climbs the walls. I would still deal with it the rest of this season and then fix it after the season is over... But the **** thing mainly turns at the water line. So it takes 5 times longer to clean the pool now. It still works but instead of 1 to 2 hours, its 7 to 8 hours to clean the pool...
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    BTW, you seem to know a lot about the robots. Im thinking of buying a new one for next year because as much as I love the T2, there always seems to be a problem with it. I learned enough now to change the tracks, belts, etc... But those motors are **** and when they go its ridiculously expensive.
    So if I get a new one next year, is there something that works well that wont cost and arm and a leg to get repaired?
    38,246
    Yeah, that is pretty much what I learned after the fact ... repairs out of warranty are too expensive. I thought I did read that the Aquabot line was much easier and cheaper to get repaired (even DIY).
    Looking online now it almost looks like the Maytronics robots are now being branded by Hayward and Dirt Devil ... they look very similar, but hard to be sure.
    Apr 2011
    WPB, Florida
    51
    Thanks for all the replies, I was just about to order the 9300 when I decided to check this thread again.
    Can you explain this, what do you mean by clean in one direction???
    J
    Oct 2007
    Parkland, FL
    752
    Quote Originally Posted by sharpie101
    J
    dont know the specifics, but I was told by the patent holder that is the case, will only clean in one direction.
    Oct 2007
    Parkland, FL
    752
    they all break. no getting around that unfortunately, i been through 3 and countless motors. I would probably go blue diamond as you get a 4 year warranty. so at least it lasts for 4 years. although my blue diamond remote as in the shop about 6 times in 2 years, when I got it, i believe warranty period was 2 years.
    the smart pool ones also look decent although they are made in china instead of israel so they are cheap. but at least you can buy the motors and pop them in yourself if needed. But how long will those parts be around?? that is the question.
    the problem is the non remotes pulse to change direction on the floor, which basically means they hop and do wheelies while going in semi circle, when it works, it works, but often it doesn't work that well. thats why the remote bots are so great. but they cost an arm and a leg to fix and they will break often, every part is twice as much including the cable etc. the designer told me not to bother witha remote because they are more hassle than they are worth. And we know, we've fixed the thing at least 6 times.
    Quote Originally Posted by mitch08
    J
    When the 9300 moves forward it vacuums, when it reverses it doesn't. Just spins the rollers.
    I have a Dolphin Dynamic, this is it's sixth year and it is still working perfectly. Having a robotic cleaner last that long isn't unusual, nor is having one break sooner than six years. None of the available brands are perfect, but all of them are significantly more reliable on average than has been implied above. That doesn't mean you won't be one of the unlucky ones and have a cleaner that breaks quickly. That isn't common, but it does happen. Don't expect a robotic cleaner to last the life of the pool, but they will last several years on average.
    The Blue Diamond consistently gets the best reviews of all of the robotic cleaners.
    Oct 2007
    Parkland, FL
    752
    you are lucky, read some of the reviews on the dolphin on amazon, every review talks about the motors going out. mine never broke either. but the fact that it needed to climb the wall to change direction was a deal breaker in my pool.
    my blue diamond broke constantly. my robot that I beta tested also broke fairly regularly. this was straight from the guys that designed it. what motors do you think were in it? blue diamond and the one I tested they all use the same stuff. bravo, viva, etc, all the same. most of the robots all use the same components.
    Apr 2011
    WPB, Florida
    51
    After almost a year, I thought I update this thread.
    I ended up buying the Polaris 9300XI. Here is my take on it:
    Pros:
    - Works as advertised and cleans the pool very well.
    - The bag is extremely easy to clean (my 5 year old does it most of the times!)
    - The caddy is extremely helpfull in wheeling it out to the pool.
    - If I drop it in the Spa (7'x7') it will clean the bottom but not the seat bottoms, good as I wasnt even expecting it would work there.
    Cons:
    - Does not work on the tanning shelf
    - I am always afraid it will get stolen, so I have to use it while I am at home
    If I do it again, I would order the one without the remote control. I have only used the remote once in the spa ... thats it.
    I bought it through http://www.poolsupplyworld.com and received it within 3 days, very happy with their service as I have since purchased a few other things from them.
    J
    May 2011
    Orange, TX
    66
    I agree the Polaris 9300 has worked well for me and the filter is extremely easy to clean. The only downside I have seen to this robot compared to others, ie Tigershark is the mircron rating on the filter is not quite as good. Thus, some smaller particles will pass through. Overall very happy with the product.
    20,500 gallon free form, 6X9 hot tub w/ spillover, 18" jumping platform w/ 3ft shear descent on chopped rock, Travertine coping, 2.5HP Hayward 2-speed filter pump, 525 Hayward Cartridge filter, 350K BTU Hayward NG Heater, 2HP Hayward water feature pump, Satin Matrix Northshore Carribbean, Jandy PDS-8 Controls
    Aug 2010
    Dallas, TX
    4,052
    Mine doesn't have the remote control, and there have been many times I wish it did.
    Apr 2011
    WPB, Florida
    51
    Robbie,
    The remote is not as intuitive as you would think. Its a pain to use, thats why I don't even bother.
    J
    MattM's Avatar
    Jul 2011
    San Diego, CA
    299
    I have a dolphin with a remote and find the remote worthless, except that it is the only way to select which program the dolphin will run -- e.g. slow extensive clean of floor, floor + tile, just tile, etc....although 90% of time I just have it on the standard program. So, doing without a remote I think is fine....a good robot is fast enough that it will cover most of the floor quickly enough that pointing it at a specific location just isn't needed.
    24K gallon inground gunite/pebble sheen pool, 34'x16' 4-7.5ft deep, 750sq ft solar, pentair ultratemp, intelliflow vs+, ic60, intellichem w/ acid pump, quad de 100, intellibright 5g, intellitouch i5-3s with Screenlogic2, 3" primary piping - 2.5" at equip pad, auto switched deep heating and main returns, automatic safety cover w/ electronic lock and embedded recessed undertrack, sealed stamped concrete deck, dolphin deluxe 5, started up December 2011.
  20. Back To Top    #20
    Feb 2011
    Portland, OR
    51
    I have a older dolphin without a remote and a newer one with the remote that I am using now. I don't use the remote often, but it is nice if I'm expecting company and there are just a few spots of dirt in the pool that need to be cleaned.
    The motor went out on my older dolphin but it was within the warrant period so the repairs were free, but it cost quite a bit to ship it to the repair facility from where I live. I have gotten pretty lazy and I can't imagine cleaning my pool now without a robot.
    10,000 gal Inground Fiberglass Pool;Aquarite SWG; Hayward H Series Gas Heater;
    Hayward Sand Filter; 1.5 HP Hayward Max-Flo VS Pump; Dolphin Pool Cleaner; TF100 Test Kit
