Results 1 to 8 of 8
Thread: uhhh.. new guys question on returns
    Hi,
    We just bought a house with a 20k gallon pool. It has a built in spa. There are 2 returns to the main pool and 3 returns to the spa. I have the valves set to pull from the pool's 2 bottom drains and skimmer and to return to the pool. The valves are not set to the spa at all- since I am not using the spa and want all the flow i the main pool. However one of the spa returns is still on.....
    Can I just plug or cap off that return to get better pressure from the 2 returns in the main pool? Will plugging it off damage anything?
    Also.... what direct should the eyeball returns be aiming? I have them set to turn counterclockwise, aiming towards the deep end where the skimmer is...
    Any help is appreciated!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Re: uhhh.. new guys question on returns
    You must have some water circulating through the spa. Otherwise it will quickly go green.
    Aiming return jets is more an art than a science. Watch for debris collecting on the surface anywhere, which will indicate a dead spot, and then try moving jets to revive that area.
    thanks! Is it ok to close off a return by plugging it? The spa and pool have the same water level.. meaning the spa doesnt really cascade over to the pool. So if I plug up the one return on the spa it will still get circulation from the main pool
    Richard320's Avatar
    Jan 2010
    19,058
    Well, if a spa return is flowing and it doesn't spill into the pool, then it must be drawing from the spa somehow. So plugging a return will just suck the spa dry.
    Unless I'm completely misunderstanding you somehow.
    Hi Richard,
    Here is a pic of the pool.
    I closed the valve to the spa bottom drain and the pool pump is now only pulling from the main pool drain and the skimmer.
    I also set the pump valves to return only to the main pool (the main pool has 2 returns) but one of the 3 spa returns is still flowing (the other 2 spa returns are off).... It seems that one spa return must be tied to the main pool return line.
    I am wanting to plug off that spa return and only have the returns running to the main pool.
    The water level is the same in the pool and spa. The spa is in fact a part of the pool. It has a small wall between the pool but the top of that wall is actually under the water level of the main pool.
    Hope this makes sense.
    I am thinking that since I shut off the spa drain, turning off the spa return that is running (and shouldnt be running) wont be an issue, but I wanted to make sure that plugging a running return wont cause an issue.
    Richard320's Avatar
    Jan 2010
    19,058
    But it should be running! You won't get enough water exchange between spa and pool with just an inch or so at the surface overlapping. Unless you want to test and treat two pools...but then you won't have any circulation in the spa, so you can't, really.
    Mar 2007
    Coastalish 'down easter'
    4,160
    citadel, welcome to TFP!!
    PLEASE listen to Richard - he is giving you the best advice!
    I'm not sure if you are questioning his advice because he is the only one answering your questions, but on this forum - if no one else jumps in with advice, it means that you've already gotten what we would say/ suggest and Richard gave you the perfect answers
    Luv& Luk
    -Ted
    thanks! I appreciate the feedback. I have much to learn and I appreciate the time you guys take to help newbies!
